View Poll Results: Best cam combo
HKS 272/272
47.08%
HKS 264/264
20.76%
HKS 264/272
23.39%
Works 269/269
8.77%
Voters: 342. You may not vote on this poll
Best cam combo poll
Old Oct 25, 2004 | 09:08 PM
Mach 8's Avatar
Smile Best cam combo poll
What do you guys think is the best cam combo
Old Oct 25, 2004 | 09:28 PM
2k4EvoVIII's Avatar
Well non of your choices are the best cams IMO. Tomei and Piper along with Revolver are producing the best cams for the EVO at the moment. Piper is the most aggressive with Tomei right behind followed by Revolver. HKS cams really are not all that great but for the money you get what you pay for.
Chris
Old Oct 25, 2004 | 09:34 PM
EvoJeff's Avatar
What about the Jun cams? What are the degrees on the piper and tomei cams?
Old Oct 25, 2004 | 09:45 PM
2k4EvoVIII's Avatar
Oh ya forgot about the JUN cams. If you are talking about duration when you say degrees duration is not always best. When you get too much duration you get blow through and are making less HP then before. Here are some specs on the cams for you to check out. The JUN cams are allot better then the HKS cams but they still lack the lift that the other cams provide. IMO the lift is more important then the duration. Plus you dont have the chance of blow through.
Chris
HKS 264:
Duration of 264 deg
Duration of 206 deg @ 1mm
Lift of 10.8mm intake / 10.2mm exhaust
Stock valve springs OK
HKS 272:
Duration of 272 deg
Duration of 214 deg @ 1mm
JUN 264:
Duration of 264 deg
Duration of ___ deg @ 1mm
Lift of 10.5mm
Upgraded valve springs required
JUN 272:
Duration of 272 deg
Duration of 235 deg @ 1mm
Lift of 10.8mm
Tomei Poncam:
Duration of 260 deg
Lift of 10.7mm intake / 10.2mm exhaust
Tomei Procam:
Duration of 260 deg
Lift of 11.5mm
Piper Ultimate Road cams:
Duration of 265 deg
Duration of 217 deg intake / 211 deg exhaust @ 1mm
Lift of 11.5mm intake / 10.8mm exhaust
Piper Rally cams:
Duration of 265 deg
Duration of 217 deg @ 1mm
Lift of 11.5mm
Piper Race cams:
Duration of 272 deg
Duration of 224 deg @ 1mm
Lift of 12.0mm
Old Oct 25, 2004 | 10:24 PM
Rez90's Avatar
i have the HKS 272s...and i freakin love them
Old Oct 25, 2004 | 10:29 PM
TD05HR's Avatar
i just installed 272/272
take a look
https://www.evolutionm.net/forums/sh...d.php?t=105349
Old Oct 25, 2004 | 10:31 PM
MrBubbler's Avatar
Chris
on the contrary for the stock turbo that would be true but for upgraded larger turbos for some reason the high lift isnt working to well on the socalevo.net side i think revolvers sucked on robi's car and some one was testing pipers
Old Oct 25, 2004 | 11:50 PM
evo81's Avatar
jun would be my choice of cams also
Old Oct 26, 2004 | 12:36 AM
DocMortal's Avatar
Torque is best for a street race, im my opinion , thats why I went 264 264...
Im sure theres better cams but I love mine..
Old Oct 26, 2004 | 12:44 AM
megatron's Avatar
indeed, i got the 264/264 combo for the all around performance aspect. perfect for taking to the track because you have a lot to play with throughout the entire powerband. isnt that where the evo should dominate anyway? i have no complaints with any top end loss. theres something dissatisfying about dumping money into my car just to drive in a straight line. but dont get me wrong i still love the dragstrip.
Old Oct 26, 2004 | 05:52 AM
Lacoste's Avatar
Question
What about 272/264? I saw some postings saying (I think) that this was more balanced intake/exhaust similar to the ratio the Evo has stock.
Lac
Old Oct 26, 2004 | 12:40 PM
binsquared's Avatar
Anyone know how idling is with those cams?...Am planning on getting cams (leaning towards 264/264) but i want my car to sound subtle...not like a mean a$$ gvr4
EDIT:: im probably gonna be taking my car to autocrossing instead of the usual drag strip...what you think is the best set-up?
Old Oct 26, 2004 | 12:49 PM
Wrathafier's Avatar
jsut got the hks 272 intake and exhaust cams with hks cam gears and hks reinforced springs and titanium retainers, havent installed yet but i think its gonna be one hell of a ride
Old Oct 26, 2004 | 12:50 PM
siantjab's Avatar
For autox 264/264 is going to be perfect.. Lots of low end torque. That's what I have and I can't complain at all. Power delivery is excellent and with the Dynoflash idle flash there is very little lope (very very little), and it feels like a stock idle (A/C or not).
Old Oct 26, 2004 | 01:00 PM
binsquared's Avatar
^ Thanks...Now definately going for them...
