Dynoflash vs. SAFCII
Old Oct 26, 2004 | 09:20 PM
  #31
DSMotorsport's Avatar
Bam there you go...strait from the horses mouth.
Seems the flash has more merits than i originally thought.
Old Oct 29, 2004 | 06:09 PM
  #32
GREDDY's Avatar
Originally Posted by DynoFlash
Could you kindly post up a dyno sheet? I would be interested to see what it looks like with 91 octane.
Ok, give me a couple of days. When I dyno'd at MAC motorsports, I forgot to bring a disk so I didn't get my dyno run on it and I don't have a scanner either. They can't email it either so I'll have to drive up there to get a copy of it on disk.
Old Oct 29, 2004 | 06:26 PM
  #33
DynoFlash's Avatar
thanks
Old Oct 29, 2004 | 08:53 PM
  #34
RyanM's Avatar
The fuel pump is still a good idea as you continue to mod, not a bad thing to have. The AEM wideband works great. (don't do what I did and get something off breed to save money, the voltage is wrong for either the AEM or Autronic EMS )
Definitely just get a drop in filter or go with an airbox like the ARC. I have the HKS RS, I know I have gains at WOT, but I also have compressor surge for the 90% of the rest of the driving that I do--which I'm not pleased about. But it does look kick *** so at least they got that right.
If I had do overs, I'd go with the ARC box or APS induction as compressor surge is not a problem for that unit. I'd also definitely get the AEM wideband. There are tons of choices out there for a wideband.
You can also get an Apexi turbo timer and use the narrowband O2 sensor. Its not as accurate, but let me define that. The number fluctuates more than a wideband. If you hold an RPM and give it a chance to stabilize (as in about 2-3 seconds) the reading is VERY close to the wideband. Its not good for road course tuning but gives you a good rough idea.
Old Oct 29, 2004 | 08:59 PM
  #35
RyanM's Avatar
An added note on the SAFC. I installed it as my first mod and definitely had the knock issue Dynoflash is talking about. However, the HKS RS eliminated that issue so I have to give them credit in that department. I get almost no knock whatsoever now, I had to double check my wiring to make sure it wasn't loose because I went from 8 at idle to 0 and almost no knock throught the power band.
shadow1
Jun 2, 2008 05:37 AM
chizcwish74
Jul 28, 2005 03:10 PM
gorf
Jun 6, 2004 11:42 AM
Justin1933
Jan 9, 2004 03:57 AM
