EVO Fuel Filter Location
Old Nov 1, 2004 | 03:39 PM
KillaSweep's Avatar
Hey guys...i did a search, but only found stuff for the OZ. Where is the fuel filter(s) for the Evo? My car is starting to act up again. Last time it was crap in the fuel filter and the fuel pump. I wanted to see if i could pull the fuel filter to see if it is somehow getting loaded with crap again. Thanks for the help!
Old Nov 1, 2004 | 03:42 PM
Kinmar_X's Avatar
i believe you can access it from under the rear seats. can anyone confirm? I know thats how you access the pump anyway.
EVOTEXAS's Avatar
In the tank attached to the fuel pump. Otherwise, I don't think there is one.
Old Nov 1, 2004 | 03:48 PM
freedom's Avatar
A better description would be the pump is attached to the fuel filter.....
Basically the complete assembly including float must be replaced for a good bit of money.
Old Nov 1, 2004 | 04:02 PM
PVD04's Avatar
The fuel filter is attached to the fuel pump. The whole assembly does not have to be replaced. The filter can be replaced on its own. Just search for the instructions on how to install the Walbro fuel pump to see how to remove the stock fuel pump. The filter is attached to the bottom of the pump. Shouldn't take you too long to pull the pump and visually inspect the filter.
Old Nov 1, 2004 | 04:23 PM
freedom's Avatar
I'm sorry to say that you have this wrong. The filter you cite is just a pickup filter. The real filter is up inside of the assembly.
Old Nov 1, 2004 | 04:25 PM
Zeus's Avatar
Better known as the strainer...
Old Nov 1, 2004 | 04:37 PM
freedom's Avatar
Yup..that is the word I was looking for
Old Nov 2, 2004 | 05:34 AM
KillaSweep's Avatar
cool...thanks for the help!
Old Nov 2, 2004 | 08:09 AM
DynoFlash's Avatar
Frankly - its one of the only things I rellay do not't like about the evo - in a year or two a lot of guys are not going to like to shell out $280 to change the fuel filter
Old Nov 2, 2004 | 08:34 AM
JustDSM's Avatar
^ Thats why they should buy some simple hand tools, a FSM.
dragon831
Nov 3, 2011 11:58 AM
Mr. Evo IX
15
Oct 25, 2007 08:28 PM
Crazy4Cars
Jun 13, 2004 07:41 AM
hotfire007
Lancer Troubleshooting
Oct 8, 2003 02:41 AM
