Stock Oil Temps?
Old Nov 3, 2004 | 07:04 AM
bolsen's Avatar
Stock Oil Temps?
What are you showing for stock pil temps in F?
Old Nov 3, 2004 | 09:34 AM
Karash's Avatar
On the highway, I see normally 90C which is 194 F
If I really push the car with a lot of boost for extended periods of time I normally go 100C which is 212 F
I live in Oklahoma btw.
Old Nov 3, 2004 | 09:53 AM
bolsen's Avatar
hmmm....
Old Nov 3, 2004 | 10:04 AM
skiracer's Avatar
In Celsius in my OEM factory gauges, i see 70 degrees highway driving, 75 degrees city driving.
Old Nov 3, 2004 | 10:08 AM
Greg K's Avatar
65-75 degrees C here. That would be about 150-170 degrees F. I've seen it higher, but never over 212 F. I live in the cool and wet Pacific NW.
YMMV,
Greg
Old Nov 3, 2004 | 10:15 AM
2literturbos's Avatar
65-75C just rolling around
the 80-95C giving it hell, Just keep it under 100C and your fine
-James
Old Nov 3, 2004 | 01:00 PM
Fireball's Avatar
Mine says 185 - 205ish.
Old Nov 3, 2004 | 05:33 PM
evoracerx's Avatar
85-95 C depending on speed. Wrap your DP with heat tape and it will cool it about 3-5 degrees C. Track Temps are 125 C when the outside Temp is 100+
Old Nov 3, 2004 | 05:52 PM
plokivos's Avatar
ok, what is that on the stock oil temp gauge? Mine is always a click down from half way point.
Old Nov 3, 2004 | 09:00 PM
Evo442's Avatar
70 degrees celcius just cruising around. Not much past 90 degrees celcius even with aggressive driving. Havent tracked the car though. temps get above 100 degrees farenheight where I live
Old Nov 4, 2004 | 05:26 AM
modvp's Avatar
~190-205 F
Old Nov 4, 2004 | 05:41 AM
Az3ar's Avatar
160~170 just driving around . 180~190 on long freeway drivers 45 min to 2 hrs. when i push it and race i see 200~220 some times. mine reads right from the oil plug.
hatakashi
Aug 24, 2015 05:32 AM
FQ640
Nov 21, 2011 01:49 PM
yesevo
11
Oct 31, 2011 10:19 AM
evascst
Aug 11, 2011 07:48 AM
bnr34rb26dett
Dec 7, 2010 12:28 AM
