compression test done after break in results
Old Nov 4, 2004 | 10:58 AM
use2vtec's Avatar
Today was such a nice and sunny day outside I just had to go tinker with the car. I figured since I just completed my break in a few days ago that I would go out there and do a compression test. My results were 175-175-173-173. The engine was warm but not hot when I did the test. I looked up other members results and I think I am right where I should be. I guess its time to start ordering performance goodies.
Old Nov 4, 2004 | 10:59 AM
GOKOU's Avatar
sounds like it was a quick job. Any instructions?
Old Nov 4, 2004 | 11:09 AM
use2vtec's Avatar
Yes it is very easy to do.
First off dont do it when engine is really hot.
1. Pull off spark plug wire cover. (4 10mm bolts)
2. Remover the 2 coil packs located above cylinders 2 and 4. (3 10mm bolts on each coil pack)
3. Remove spark plug wires off of cylinder 1 and 3.
4. Remove all spark plugs.
5. Remove Fuel pump fuse located under hood on driver side fuse/relay compartment
6. Install compression tester into cylinder 1.
7. Hold gas pedal to floor and crank engine 5-6 times.
8 Repeat steps 6 and 7 through the rest of the cylinders.
Compression test complete.
Old Nov 4, 2004 | 03:10 PM
GottaGoFaster's Avatar
Pics of each step would be the **** for us mechanically uninclined
Old Nov 4, 2004 | 06:36 PM
use2vtec's Avatar
I apoligize for no pics. I wasnt going to make it a how to post but someone asked so I explained it the best I could. Next time I do one I will post pics.
AKB_EVO
Dec 12, 2016 08:02 PM
repto
Mar 6, 2016 05:02 AM
EvoIXPilot
Feb 13, 2013 02:01 PM
Colbyy
28
Jul 19, 2011 06:38 PM
dierr
Northwest Region
Sep 3, 2008 01:44 PM
