NEED HELP Cam install, won't stay running
Old Nov 5, 2004 | 05:12 PM
  #46
DizzyTT's Avatar
The cams came straight off, the new ones went back in, straight in, moved less than a millimeter to get them in the cam gears. We are currently of the opinion that it isn't timing, it seems to be fuel.
Old Nov 5, 2004 | 06:02 PM
  #47
Jorge T's Avatar
The way I check for fuel is to remove the return line of the fuel rail, add hose to the outlet and dump it to a container . Then start the car fuel will come out of the return line, if not then there is your problem.
I also use this method to remove all fuel from the gas tank and add higher octane fuel, no mix!
Old Nov 5, 2004 | 06:04 PM
  #48
DizzyTT's Avatar
stupid question. the return line is the one on top in gold/brass, right?
Old Nov 5, 2004 | 08:06 PM
  #49
DizzyTT's Avatar
Ok, found out the fuel pump had a loose connection. We fixed that, have fuel flowing, it will start, run for 5-6 seconds in a well balanced manner (not skipping or hesitating), then quit, sounds like a fuel cut. Spark plug is staying dry (like it's burning the fuel).
Old Nov 5, 2004 | 08:18 PM
  #50
TampaTurbo's Avatar
strange. I am glad you mentioned a loose wire on the fuel pump because I was going to suggest that since those 2 wires (blue and black) easily pop off when you pull on the fuel pump a little too hard taking it out.
Old Nov 5, 2004 | 09:01 PM
  #51
DizzyTT's Avatar
ok, engine runs for about 3-5 seconds smooth, then quits like fuel cut.
Old Nov 6, 2004 | 05:30 AM
  #52
DizzyTT's Avatar
It's ALIVE!!!!, It's Alive!!!. Ok, it still won't stay running, but I started it, and got real aggressive with the throttle and she ran for 30 seconds or so, but still won't stay running at idle.
Old Nov 6, 2004 | 06:33 AM
  #53
GOKOU's Avatar
Stupid Q but is the MAS plug in? reset ECU? Vacuum leak? Timing off?
Old Nov 6, 2004 | 07:12 AM
  #54
Nad1370's Avatar
Just wondering...If you held it at 1500rpm's , would it stay running or fall flat on it's face just like it at idle?
Old Nov 6, 2004 | 07:28 AM
  #55
DizzyTT's Avatar
Mas plug is in, ecu is reset, vaccum seems normal, timing is spot on according to the indicator marks. No, at 1500, it still dies.
Old Nov 6, 2004 | 07:34 AM
  #56
Nad1370's Avatar
Tubo timer installed ? I'd take it out and re-check. Could be something faulty in the Timer.
Old Nov 6, 2004 | 07:35 AM
  #57
DizzyTT's Avatar
No, haven't installed my turbo timer yet (sitting in toolbox waiting)
Old Nov 6, 2004 | 08:21 AM
  #58
Nad1370's Avatar
Check out this site.
http://www.fueltech.com.au/diagnostics.htm
Hope this helps.
FWIW..I'm leaning towards your EFI temp switch being bad. Had this problem on a Toyota that would just stop running. No codes thrown. Replaced the $30 part and it's fixed.
Old Nov 6, 2004 | 09:52 AM
  #59
BlackEVO's Avatar
It sounds exactly like what happens with the MAS unplugged or an IC pipe off. You're absolutely positive that ALL sensors are connected? What are you running for a BOV and is it recirculated back to the intake pipe? If you've done anything with the intake pipe/MAS, make sure the clamps are tight around the MAS and turbo inlet.
Old Nov 6, 2004 | 02:28 PM
  #60
DizzyTT's Avatar
put oem cams back in, returning car to stock, mitsu will come and take it and fix it hopefully.
