EFI PMS display?
Old Nov 9, 2004 | 01:39 PM
lacartus's Avatar
Question EFI PMS display?
Dating myself I'm sure, but on my DSM I ran the EFI PMS piggyback/standalone system (could function as either, used to be at www.efisystems.com but it looks like Doug is out of the DSM business) that had this handy in-car keypad display. It showed the program #, O2 reading, MAF, RPM, boost, load, etc. All the parameters could also be updated through the pad.
Do any of the EVO piggybacks or standalones have an in-car display or keypad/display? Even a palm interface would be nice...mount the palm somewhere and read it like a gauge pack.
Old Nov 9, 2004 | 01:48 PM
bigyellowevo's Avatar
I think the apex'i power-fc uses a keypad, but not for sure.
Old Nov 10, 2004 | 06:35 PM
DSMotorsport's Avatar
yeah...I belive the only system like that is the Apexi Power FC standalone.
The EMS needs a laptop to tune and download logs, but it logs internally and doens't need a laptop to run.
Old Nov 11, 2004 | 05:16 AM
lacartus's Avatar
Bummer, it doesn't look like, judging from the lack of posts in that forum, that a lot of people are using the PowerFC on the EVO. I think I'm done with the pioneering thing, tried-and-true is so much easier.
I was kind of hoping the AEM, XEDE, or UTEC had some Palm software that could work as an in car gauge pack.
Old Nov 11, 2004 | 07:28 AM
juyanith's Avatar
I don't know if it's what you are looking for, but the ecu+ has software for the palm (www.ecuplus.com). There is also some software for the innovate wb (www.innovatemotorsports.com) that you might like, but it's strictly datalogging. You'd have to use something else for tuning.
Old Nov 11, 2004 | 07:33 AM
kcevo's Avatar
You could try this www.gauge-tech.com for the AEM for $400. I ended up building an in car computer that sits under the seat and uses a 7" touch panel screen. Total build cost for the computer is about $1500.
Old Nov 12, 2004 | 05:23 AM
lacartus's Avatar
Thanks, looks interesting. I wonder how many people are running the ECU+ on this board. Anyone?
Old Nov 12, 2004 | 05:34 AM
lacartus's Avatar
Now that looks really close to what the PMS had. After seeing some posts on here about OBDII being used in state inspections, I see that it's been added to the PA code: http://www.pacode.com/secure/data/06...hap177toc.html
OBD I/M Check is the procedure where they connect an analyzer to the OBDII port on 2001 or newer vehicles and look for error conditions.
As others have mentioned in other posts this would pose a problem for the AEM since it doesn't interface with the OBDII port. The OEM ECU could be replaced for inspection, but it would have to run well enough to pass the sniffer in PA. ...and that would be a pain.
New AEM 3rd party add-on: OBDII port simulator Anyone?
Old Nov 12, 2004 | 06:32 AM
kcevo's Avatar
It is a plug and play standalone, so you could keep your stock ecu and install it when you need to do an obd2 scan.
Old Nov 12, 2004 | 06:41 AM
D1_EVO8's Avatar
Microtech has a keypad or laptop or DASH unit that shows different inputs/outputs. www.microtechusa.com
yoyojimmy
Nov 11, 2013 11:18 PM
Bueller
Jun 22, 2011 10:56 PM
Maximum Output
Evo 'For Sale' Electronics / Lighting / Audio
Feb 10, 2010 02:18 PM
Maximum Output
Jan 15, 2010 04:23 PM
cantcatchme96
Jun 21, 2008 09:47 AM
