Problem with Blitz Turbo Timer
Old Nov 11, 2004 | 09:30 PM
Blue car's Avatar
Well just fitted a Blitz Full Auto Turbo Timer (the old version, which is the first one), and whenever i turn on the ignition, the FATT waits for a few seconds then turns red even while car running (regardless of the mode)! it starts ticking to initiate count down, but the timer doesnt move.. turns zero when i switch off the car and it stops immediately.
have i screwed up the wiring, or is the FATT not working properly?
thanks for the help
Old Nov 11, 2004 | 09:35 PM
lqdchkn's Avatar
Something's definately messed up. I installed mine last weekend in about 4hours with no problems. Did you use an ignition harness or splice the wires youself?? How about hooking up to the parking brake switch??
Old Nov 12, 2004 | 03:28 PM
Blue car's Avatar
No i am using a harness, but the harness was made for the newer models of the turbo timer and i had to rewire turbo timer connection only, the male and female connector to ignition is fine!
i dont want to connect to hand brake, i thought it wasnt necessary?
thanks
Old Nov 12, 2004 | 06:27 PM
sillypuddy's Avatar
i think you have to ground the handbrake wire no?
-joe
Old Nov 12, 2004 | 06:36 PM
DrBump471's Avatar
I use the Blitz D1 Spec Turbo Timer. Installed it about 5 months ago and has been working like a charm ever since. You will need to install the ground wire (mine was purple from the turbo timer, I think) to the hand brake groun. This is so no one can drive away with your car for approximately 1 minute.
If I turn off my key with the hand brake down the car immediately shuts off. When the hand brake is up the car will countdown for the time I have asked it to.
My guess is you should go back through your wiring and ground the wire to the hand brake ground.
-Jason
Old Nov 13, 2004 | 11:27 AM
lqdchkn's Avatar
Yeah, you need to hook up the purple wire to the handbrake (preferred) or just ground it.
Old Nov 13, 2004 | 12:20 PM
1QWKEVO's Avatar
you need to either ground the purple wire or hook it to the hand break... thats the problem.. I've check this before
Old Nov 14, 2004 | 03:02 PM
Blue car's Avatar
thanks for the reply everyone.
so basically just ground the purple wire to the car just like i did with the black wire?
can anyone tell me how i can connect to handbrake switch if i want to? i would like to avoid cutting the wires from the car, wouldnt mind cutting tt wires though
thanks again
Old Nov 15, 2004 | 05:43 AM
sillypuddy's Avatar
use the red splicer that came with your turbo timer.. you just pinch it on the handbrake wire
-joe
Old Nov 15, 2004 | 08:24 PM
Blue car's Avatar
dont have any red splicer, got the timer as it is from a friend as a gift
well i think i get it what u mean by grounding puprple wire to handbrake switch, ill give it a shot, thanks everyone
S.Brewer
Oct 21, 2013 08:47 AM
vortico
Aug 29, 2011 12:53 PM
crazynyevo
For Sale - Cars For Sale
Mar 29, 2006 11:16 AM
Vivid Racing
10
Sep 18, 2003 09:46 AM
KillaSweep
Jul 28, 2003 06:06 PM
