Comparing the 5 speed EVO trans to the 6 speed MR trans
Old Mar 5, 2005 | 08:54 AM
  #121
bbbwrx's Avatar
Originally Posted by evoRS04
No Comparrison The Mr 6 speed Is 100% Better Than The 5 Speed!
That might be true to you but it really depends on what you use the car for. With a slow spooling big turbo you don't have to fall out of the boost as much in a drag race on the 5 speed.
The 6-speed will keep you in the torque curve easier in turns.
If the 5 holds more power then it will be used for the drag cars or high HP track cars. If not it will most likely be used for drag mainly
Ben
Old Mar 5, 2005 | 09:21 AM
  #122
favre95's Avatar
getrag makes the evo transmission-6spd anyway...not sure about the 5spd
Old Mar 5, 2005 | 11:21 AM
  #123
MR-SilverEVO8's Avatar
Originally Posted by superz
Yes, this is very true. However the MR 6 speed is not stuffed in the 5 speed case, instead it has its own bigger case which looks bigger from every aangle than the 5 speed , therefore I dont suspect that the gears are any weaker.
You are righ, the case is bigger. Still, I've heard and read that the space needed was still very scarce.... I don't think the MR 6 speed tranny is weak. Personally, I was extremely impressed with the 6 speed tranny and although the gear ratios are not so different from the 5 speed, they definitely feel better (more adequate for each speed) and there is also a noticeable difference in 6th gear cruising... It feels a lot higher that the 5th gear in the 5 speed... I know it's not so much higher numerically, but it feels tremedously different.
The biggest problem I had with the 5 speed is that I always thought it needed another gear to cruise. It always felt it was over-revving while cruising at highway speeds (specially around (70-85mph). It feels much better now anf the gas mileage is improved slightly as well.
Overall, I give the 6 speed the edge in overall driving improvement. Maybe for drag racing the 5 speed is better, but really I don't drag race a lot. Most of my driving requires the use of more intermediate ratios rather than less.
manthny18
Apr 4, 2017 03:09 PM
Paulevo9
Oct 30, 2016 11:15 AM
Evo MR IX Fritz
Mar 2, 2016 04:04 PM
TOKYO EVIL
Oct 6, 2015 07:44 PM
djdnav
Oct 9, 2012 01:21 PM
