View Poll Results: P0300 Code Poll
Less than 15K miles and no P0300
27.78%
15K Miles or more and no P0300
38.89%
P0300: dealer reflash fixed to-date
0%
P0300: dealer reflash didn't fix; nothing else done to-date
27.78%
P0300: tranny replacement fixed to-date
0%
P0300: tranny replacement didn't fix; nothing else done to-date
0%
P0300: Other things beyond above tried - fixed or not to-date
5.56%
Voters: 18. You may not vote on this poll
P0300 Code
Old Nov 17, 2004 | 06:56 PM
KazzEvo8's Avatar
P0300 Code
Let me know, read the responses carefully and pick the one that fits ... please relate any other service performed by the dealership if you care to - particularly if it has seemingly fixed your P0300 for now - let us know for how long it's been gone!!!
Thanks!
Old Nov 18, 2004 | 10:32 AM
plokivos's Avatar
it's been about 3000 miles and no mis-fire. If you get the dealer flash, your dynoflash gets erased, as well as you can't use your piggy back EMS.
that's the only draw back.
What the dealer flash does is desensitize the sensitivity on the ECU. So even if it does misfire the CEL light wont light up. Unless it's strong.
Old Nov 18, 2004 | 10:52 AM
cokofellah's Avatar
since the reflash, I would still get the SES light - although not as often.
and when I would get it, it would eventually disappear after about 10 cycles.
and then I would get it again, etc. etc.
about the only "change" I've done was to use NGK BPR7EIXs...did not mess with the gap (whatever it was).
before that, I had been messing with copper plugs (BPR 7, 8, 9! Ess).
also, mine comes on at about -10 vacuum, 80+ miles, 3500+ rpms, 5th gear - ONLY
so in my case, it wasn't "fixed" - it just happens less often now
Old Nov 18, 2004 | 07:52 PM
KazzEvo8's Avatar
*bump*
Old Nov 19, 2004 | 01:01 AM
BuLocal's Avatar
I gave up on the dealer. I keep a scan tool that conects to my Palm in the car and just clear it. It lights up 2 or 3 times every 2,500 miles or so.
Old Nov 19, 2004 | 01:42 AM
construct1's Avatar
I had the problem early on first at 1200 miles and then about 2800, both times went to the dealer and had them clear the code, but then changed the plugs to ngk BPR 7es and have not thrown a code since and have almost 20,000 on the car
Old Nov 21, 2004 | 11:05 PM
plokivos's Avatar
funny thing is, the dealer flash cleared my p0400 code for lack of cat. So I may pass emissions, hopefully.
I have no cat.
Old Nov 23, 2004 | 12:28 PM
boomn29's Avatar
Seems like a lot of people have been changing their sparkplugs and having good luck with that as a remedy? Better luck than with the dealer re-flashes anyways... and those of us running an aftermarket reflash wouldn't have to worry about getting it overwritten.
Old Nov 26, 2004 | 08:06 PM
KazzEvo8's Avatar
*bump*
Old Nov 30, 2004 | 09:06 AM
nbpal4000's Avatar
im about to get mine back from dealer today..hope it wont come on again
Old Nov 30, 2004 | 01:08 PM
TampaTurbo's Avatar
you know what stinks. If you have more than one code popping up you never know if the flash fixed it or not. =(
Old Nov 30, 2004 | 06:38 PM
KazzEvo8's Avatar
10 ain't a good enough sample size... *BUMP*
Old Nov 30, 2004 | 06:54 PM
boomn29's Avatar
Well, there was no option for 'I have the problem but haven't done **** to fix it yet, I'm waiting to hear from others' so I didn't vote!
Old Nov 30, 2004 | 09:10 PM
KazzEvo8's Avatar
*LAUGH*
This poll-starter's in the same boat and about to turn 30K...
Smogrunner
Jun 26, 2017 03:54 PM
NightHawk
Sep 18, 2016 08:35 PM
302Squill
Mid-Atlantic Region
Aug 21, 2015 09:22 PM
Grifter_MP5
176
May 5, 2010 12:39 PM
Muramasa
Mar 8, 2004 03:21 PM
