Engine Oil Residue on the two trailing arms
Old Nov 19, 2004 | 07:50 PM
ArchieBabes's Avatar
I went under the car today to check why oil residue always apear on my driveway.
I found out that there was oil on the two trailing arm, the one near the downpipe, and it was covered in dust with oil. I have to take a whole bunch of paper towel to clean out the oil under the car.
Where is the oil coming from? I can't seem to find it.
Please help, the car seems to run fine and powerfull, I just can't figure out where oil is dripping...
Old Nov 19, 2004 | 07:58 PM
JTB's Avatar
JTB
Check that your oil filter and drain plug is on tight.
Was the oil recently changed? It could be residue that is dripping from a sloppy oil change and blowing around the underside of the car.
Old Nov 19, 2004 | 08:30 PM
I checked and the plug is tight and the oil filter is the same. I change my own oil and filter.
I can see oil near the transfer case, and starter.
Old Nov 19, 2004 | 08:35 PM
Nad1370's Avatar
If there is oil on the starter, then it's probably your oil return line from the turbo.
Old Nov 19, 2004 | 09:07 PM
Ok, thanks I will check it out, there is also some oil on the lower intercooler piping coming out from the turbo.
Old Nov 20, 2004 | 06:15 AM
freedom's Avatar
Unhappy
To be honest I have the same problem in that you can see the right hand arm has a oil film with dirt stuck to it. There isn't so much oil as to make a mess elsewhere under the car or on the ground. At ~2000 miles the oil level started dropping with no obvious sign that the engine was consuming the oil.
To date I have not been able to locate where the oil is coming from. It clearly isn't the drain plug or filter. I'm the only person that works on the car and I have never found any residue on or around these parts.
Someone stated that the turbo oil return line might be the cause. When I was last under the car there wasn't a leak at the pan and there didn't seem to be anything on the line. I guess I will look again given the comment about finding oil on the intercooler hose.
I would be very interested if people can report where they found oil leaks on their engine.
Old Nov 20, 2004 | 06:25 AM
fromgsx2evo8's Avatar
i had a very similar problem and it turned out to be my rear main seal was going bad. I would have it checked out if i were you. Dont take it to some dumb mechanic either. I would try to go to turbo trix or somewhere with similar expertise.
justin
reggiesd
North Texas Evo Club (NTEC)
20
Feb 28, 2012 09:46 AM
rd122481
Nov 25, 2011 06:52 AM
def1
11
May 14, 2011 09:14 PM
Evokid8
Jul 6, 2009 12:39 AM
hellcat
May 2, 2008 12:12 AM
