Any Profec Type S users....
Old Nov 21, 2004 | 05:55 PM
DrEvo's Avatar
I just installed my new Profec Type S boost controller, I removed my Profec Spec B II. Before the change, I was holding 20psi on low and about 23-24psi on high. When I installed the Type S, on low boost, the max it would hold was 17 psi. On high boost, maxed out, the most it holds is 21-22 psi. This was with everything maxed out, the gain knob turned all the way to the right and also the high boost knob. After a couple of runs, I went back and replaced the Type S with the Spec II and hello 23-24psi again. I then installed the Type S again and same issue no higher than 22psi. There are no boost leaks of course and the install is pretty straight forward. According to Greddy it is supposed to hold almost 43psi, but so far it doens't look like it in my case, so i wanted to see if anyone is running this unit yet. If so, is it holding boost, specially high bost?
Here is a link of the unit:
https://www.evolutionm.net/forums/sh...ht=profec+type
Old Nov 21, 2004 | 06:04 PM
Agent-Smith's Avatar
I just installed the Type-S today and I am running into the exact same issue.
I also get a waver of about 1/2 psi at any pressure if I have the gain set at anything but 0. Looks like I might take this back and swap it for the type II.
Old Nov 21, 2004 | 06:19 PM
DrEvo's Avatar
Thanks for the reply man, I hope this is just a solenoid issue from Greddy. I will give Greddy a call tomorrow to see what they say. Any vendors have any input on this?
Old Nov 21, 2004 | 06:22 PM
Let me know what they say - cause yeh this is gonna **** me off.
Old Nov 21, 2004 | 06:27 PM
DrEvo's Avatar
I will definitely keep you updated. I hope not too many people on the board bought it yet. Any one else having this issue....?
Old Nov 21, 2004 | 07:23 PM
b18flip's Avatar
DrEvo, how come you swapped the specII for the type-s? Just curious because i'm about to purchase an EBC and it's down to the spec-s and spec II. Well more the spec-s because it seems easier to work with lol.Did you have any issues w/ the spec II? Thanks for the help
-Ryan
Old Nov 21, 2004 | 07:32 PM
Geo@EvoStore's Avatar
Just call Greddy or whoever you bought it from. Greddy has pretty good customer service so it should not be a problem.
Old Nov 21, 2004 | 08:24 PM
Crazy4Cars's Avatar
`5
Old Nov 22, 2004 | 03:11 PM
DrEvo's Avatar
-Ryan
Reason being is that the Spec II can get annoying when setting your boost. Profec B the old style which I use to run, is much simpler and straight to the point. The only reason I no longer use it, is because it could only hold about 26 psi from what I've seen online. With the type s, it has the simplicity and it can/should hold about 43 psi.
Old Nov 22, 2004 | 03:26 PM
DrEvo's Avatar
Well I just got off the phone with Greddy and they said others have called about this issue also. I also told them that I wasn't the only one with the issue in our evo community. They told me that at this time they are investigating the matter and that they will get back to me as soon as they find out what is going on. I'll keep you all posted as soon as I get updates from them. So heads up to the vendors out there, you might want to call Greddy also and confirm this for yourself.
I'll have to go back to my Spec II for now until the issue gets resolved. Hope they solve it soon because it would be a great unit once this little quirk gets taken care of.
Old Nov 22, 2004 | 03:39 PM
Did you try different gain settings? You should never need the gain all the way up as you probably know. I would probably try 0 gain, 50% gain, then 15% gain just to see what it does.
Old Nov 22, 2004 | 03:57 PM
DrEvo's Avatar
Definitely tried all the gain settings, but no luck. The unit did this on both low and high boost. But it did hold boost really steady, better than my spec II did. So if you want to run no more than 20 psi for now, it shouldn't be an issue. I just need something that can go 25 plus psi.
Old Nov 22, 2004 | 06:34 PM
I can concur DrEvo's findings - I borrowed a friends extra profec II. After learning how to tune it (what a pain) I got nice solid boost - but again any gain setting over about 5% resulted in lots of waver. I was able to hit 21.6 psi with the set on 55% ( turned it back down to a reasonable 21 - warning at 21.6) i didnt set it higher but obviously it goes higher.
I dont know how DrEvo did it but I simply swapped the controllers I did not touch the solenoid at all.
Old Nov 23, 2004 | 02:34 PM
DrEvo's Avatar
Thanks for double checking. In my case I swapped out the solenoid and unit, left the
vacuum and wiring alone since they are the same. I am going to try and use the solenoid from my spec II sometime this weekend. I'll post my findings once I have finished the test.
Old Nov 26, 2004 | 01:03 PM
Any more updates?
