Limits of stock MAF/ECU
Originally Posted by fre
Utec and exede are pretty much an safc with the ability to map timing...If I have a huge knock problem then I will probably just give in and change my management, but I'm already having that problem and I'm still on the stock turbo. It only happens under part throttle in high gears. The guy im tuning with doesn't seem to think 20 degrees of advance is that extreme. He pretty much said no matter what, it's hard to avoid knock on pump fuel.
I'm one of a good several making an easy 300whp DD (350whp DJ) on pump fuel and stock turbo running an Xede, and AFAIK, none of us are experiencing any knock. Go figure, huh?
Anyway, like I said, good luck!
Originally Posted by Ted B
An Xede makes an safc look primitive by comparison. Check out the Xede's demo software. I presume the UTEC does as well.
I like the driveability of the stock ecu.
The blurb about knock being acceptable waves a BIG red flag, simply because there should not be any...at all. If there is, that indicates the ECU cannot remove enough timing to control it, and that's bad news. Ultimately, it's your car and you are going to be the only one who has to contend with it, but I strongly suggest seeking another source of advice. Fortunately, good advice is free. Replacing engine parts isn't.
That knock is telling you something.
Also, with a good tune, you should never have to "Deal with" any sort of knock.. knock protection is for when things go wrong, not as a safety net... any tuner who uses the knock protection as a feature in part of their tuning is NOT a good tuner and I would question their judgement and abilities.
With the right set of bolt-ons, it's not very hard to make 400-440bhp on pump gas. And this with the complete absense of knock. Whatever little knock you may get during regular street driving is going to turn into a A LOT of knock if you were ever to run your car hard in the heat or at a track day. Be carefull....
Shiv
Shiv
DynoFlash
Feb 16, 2010 11:44 AM
CharlieGsanD
Aug 8, 2004 08:19 PM
