Getting into the 12's
Originally Posted by smp3000
Well engine management is a ways downt he road for me. Some people have dipped into the mid-high 12's with intake, mbc, turboback, fuel pump, and a flash.
I made a 12.7 pass with that same set-up you have listed with 1.8 60fts.
Unless the manufacturer of the intake is going to reprogram your ECU as well, or you find a program specifically for your intake from someone else you might want to stay away from aftermarket intakes. Your goal should be obtainable with a stock intake, then you retain ease of use, and no funny business with MAF readings.
Yeah, I've had my own issues with the whole intake thing. The first intake I tried was the K&N Typhoon- and that was a monstrosity. Found a ton of people on here with the same problem- so I returned it and now have the PErrin shortram. It feels very strong. I dont' know how it will compare to the stock intake- without having a flash done to the ECU with the intake mod being considered.
I guess we'll see after I go to the track.
does intake really give you much gain? realistically n/a cars average 1-2whp spending like 300 dollars on a CAI or short ram or what not, where they could have spent 60 dollars on a drop in filter like k&n , but for the f/i cars , does it make a big difference? average 5 more whp???
from what I've read the intake won't do a whole lot over our stock intakes. The stock intake really isnt' that bad. Some are worse than others but if I could do it over again I'd just put a dropin filter in.
But I guess once I get the TT flash- they will consider the intake mod and adjust the fuel settings to accomodate it.
I understand all of that. I used to have a Mazda MP3 which I turbo'd- I did all the installs myself including the hard wired piggyback system.
I was jut wondering what most of you who are running 12's in this car have done.
As usual I concur with Ted B.
3" exhaust, MBC, AFC or reflash and you should be solidly into the 12's @ 105-108mph
I went 12.3 @ 108 with the above mods and the injen pipes...but Im sure It would have gone just as fast without the intake parts.
Wow, 12.3 is very impressive without cams even! What psi were you running?
on pumpgas I run around 20-21psi on racegas I crank the boost to all the stock turbo will make...25 dropping to 23
EvoXMRnoob
Mitsubishi TC-SST Discussion
41
Sep 13, 2016 11:55 PM
badreligi0n
25
Sep 29, 2014 09:10 PM
mr0072003
121
Mar 24, 2012 01:57 PM
H8ted1488
11
Jul 21, 2009 09:45 AM
