Questions....Just Installed 272 cams
Old Nov 24, 2004 | 02:47 PM
edtxag's Avatar
Ok I just finished installing all of this and I am having problems turning my car on, however if i give it gas i get it going and once i fixed the idling via the turn screw to let more air in it goes good as i rev up it does ok as well. my question is this did you all have the same type of problems which were solved via tuning or is this uncommon. I cant just turn the key anymoe and get it going i have to pump the gas pedal and it eventually starts. Like i said i also adjusted the idling via the screw and made sure the line was taught
help me out with some feedback and thoughts
-ED
Old Nov 24, 2004 | 02:53 PM
bolsen's Avatar
Did you tune for them?
Old Nov 24, 2004 | 02:55 PM
edtxag's Avatar
well it is suppose to be on my Xede but not sure if it is or not I had some issues where i might have erased the map it came with
Old Nov 24, 2004 | 03:26 PM
Ted B's Avatar
Adjusted the idle by turning the screw? That's not good in itself.
You better get some help from Vishnu.
