Tranny drain plug is hosed
Old Nov 25, 2004 | 06:33 AM
berkel's Avatar
Red face Tranny drain plug is hosed
Whatup,
I'm approaching 30K miles and just flushed the radiator with factory coolant 50:50 with distilled water, changed to NGK coppers gapped at .025 (which has eliminated ongoing misfire problems), installed Stoptech SS brake lines and Ferrodo pads all around, and bled the brakes with ATE super blue.
For the drivetrain, changed rear diff and transfer case with NEO RHD. Car runs awesome, and the tranny noise from the early life of my car is all but eliminated. Drain plugs were relatively free of metal, whereas at the last change (15K miles) they still had a fair bit of residue.
Anyway, the 24mm drain plug has some pretty rounded corners.
I bought a replacement, but I need to get the original one off first. I've tried a 24 mm socket and it just slips. Do I need to drill it out? Get a blowtorch? Any ideas?
Thanks for any input.
FB
Old Nov 25, 2004 | 06:54 AM
YellwTyper's Avatar
You used NEO RHD on every component of your driveline?
Old Nov 25, 2004 | 07:14 AM
berkel's Avatar
Whatup,
I use NEO RHD, which is GL-5 in the rear diff and tc.
I use Redline MT-90 which is GL-4 for the transaxle. Redline actually recommends a blend with MTL, but I just use straight MT-90.
Take care,
FB
Old Nov 25, 2004 | 07:47 AM
rraulston's Avatar
10" pipe wrench. I remove that kinda crap all the time. Then go throw away all your Cresant Wrenches.........
Old Nov 25, 2004 | 08:26 AM
nothere's Avatar
if it is round, try a vice grips. think of this as a last resort and a sin.
Old Nov 25, 2004 | 09:27 AM
marksae's Avatar
Are you using a 6-point or 12-point socket? I'm guessing you're using a 12-point. Try a 6-point socket. You might have a chance at removing it still.
Otherwise, you might want to try using a big vise grip.
Old Nov 25, 2004 | 10:33 AM
berkel's Avatar
thanks guys.
I looked for a 6 point 24 mm socket at sears and couldn't find one.
I'll look again. Thanks for the input all.
FB
Old Nov 25, 2004 | 11:51 PM
delivery's Avatar
i agree with the pipe wrench or vice grip.....
If NON of those work........ take a dremel and cut a slot in it and use a large flat head. that has saved me more than once.
Old Dec 2, 2004 | 06:44 PM
Rob W.'s Avatar
Ditto that. Definitely slot it and try the screwdriver method before resorting to drilling.
Old Dec 2, 2004 | 06:52 PM
2GDSM's Avatar
if you go to sears you can get one of those bolt out things...It just grips onto the side of the bolt so that you can remove it. I never heard the dremel idea, i kinda like that one. dont drill it unless its a last resort. the bolt out thing works wonders, unfortunatly I dont have the packaging anymore so I do not really know what is "officially" called.
chaotichoax
32
Feb 11, 2020 09:00 PM
SleepySamurai13
Apr 28, 2017 05:04 AM
Bom's Evo
71
Dec 10, 2013 04:32 AM
03_OZ_LancerBoy
Lancer Tranny/Drivetrain Tech
166
Jan 24, 2013 12:40 PM
sdelivery
Jan 31, 2010 08:20 PM
