Boost Taper
Old Dec 1, 2004 | 03:11 PM
90GSX-03EVO's Avatar
Originally Posted by trinydex
....you need to get a stand alone or a flash that specifically takes it out....
No way. A boost controler will take out the stock taper. The taper comes from the OEM boost control solenoid. You can hold 19PSI to redline with no problems. When you start pressing 21PSI and up, you start tapering around redline once again because of the turbo running out of strength to press that hard at that high of a CFM rate.
Old Dec 1, 2004 | 04:44 PM
trinydex's Avatar
hmm... are you positive of this? because that sounds like great news to me, but i've heard so many different stories from different people. is it really just that the stocker runs outta breath?
Old Dec 2, 2004 | 11:06 AM
I'm positive that I have installed boost controlers on both of the Evo's that I have owned (2003 GSR and a 2004 RS) and neither had any ECU work done to them at the time and it eliminated the taper.
It's simple turbocharger principles. Look at how the stock layout is. There is a boost control solenoid that tapers the boost. That is it's job. When you remove that, you remove the taper.
The first Evo I had set to run 19.5 PSI with no worries. The second one is now set to 20 PSI, again, with no worries.
Old Dec 2, 2004 | 11:18 AM
Ted B's Avatar
The turbo will not taper only if the engine can't use enough air (making enough power) to bring it to its limit.
Old Dec 2, 2004 | 11:35 AM
propellerhead's Avatar
I think there may be some confusion regarding boost taper.
One taper is 'caused' by the boost profile designed by the factory and is controlled by the ECU and boost control solenoid.
The other taper, as Ted B mentions, can occur when the CFM capacity of the stock turbo at a given pressure is exceeded. At higher RPMs and especially at boost levels above stock levels, the stock turbo runs out of breath. This is evidence by the characteristic drop in horsepower as the motor winds up towards redline.
Old Dec 2, 2004 | 05:19 PM
trinydex's Avatar
isn't there also a boost pill in one of the vac lines that causes a taper when it sloshes around.
Old Dec 3, 2004 | 06:33 AM
The pill in the line doesn't slosh around or move. It's pretty welljammed into the line. It's purpose is to dampen the action of the wastegate when the boost solenoid opens.
evo9atic
Jun 13, 2017 08:17 PM
EGHBauce
Jul 3, 2006 07:58 PM
ninjadoc
AEM EMS
56
Jan 30, 2006 07:38 AM
bigyellowevo
AEM EMS
10
Aug 12, 2005 09:51 AM
Crazy4Cars
10
Aug 30, 2003 07:56 AM
