Mitsu boost gauge vaccum reading at idle
Old Dec 1, 2004 | 10:38 AM
tokeone's Avatar
evo mr fu.
if your gauge is at 0 when the car is off then chances are the gauge is fine. if it were off (in your case since the gauge only goes to 1 bar at full boost it would be "reading" vaccum when off)
sound to me that you have a leak somewhere cause you arent reading as much vaccum or as much boost as you should be when the cars on.
however, that doesnt mean the leak is in the line to the gauge.
Old Dec 1, 2004 | 10:49 AM
redevo561's Avatar
Old Dec 1, 2004 | 10:52 AM
EVO MR FU's Avatar
what other places can I check for a leak?
what do you mean by. " in your case since the gauge only goes to 1 bar at full boost it would be "reading" vaccum when off" How does it read vaccum when the engine is off? when the engine is off its just at 0
Old Dec 1, 2004 | 10:55 AM
redevo561's Avatar
he meant when the engine is off that the neddle will be under the 0 into the vacumm section
Old Dec 1, 2004 | 10:59 AM
redevo561's Avatar
check ic pipes they tend the loosen up by the clamps check blow off vavle
Old Dec 1, 2004 | 12:43 PM
EVO MR FU's Avatar
why would the needle be under 0 if the engine is off?
ImsoevoX
Evo X How Tos / Installations
37
Apr 26, 2013 12:28 PM
LetsGo82nd
24
Apr 26, 2011 06:08 PM
redevo8driver
12
Nov 5, 2004 06:43 PM
TheeVOoNE
10
Apr 8, 2004 05:07 PM
khmerEvo
Sep 5, 2003 12:52 PM
