Quick parts updates....
Old May 18, 2005 | 10:23 AM
  #406
WannaRace's Avatar
David, will you be experimenting any further with this project or will this be the final product? I don't want to buy if there is going to be an updated version later on...
Old May 18, 2005 | 10:25 AM
  #407
Gabriel Knight's Avatar
Oh come on. =o) There will always be updates. It is the nature of the cars. The products will be improved with time and new experience/research.
Old May 18, 2005 | 10:32 AM
  #408
Hiboost's Avatar
To answer the clipping question it basically makes the exhaust wheel less restrictive for more top end flow but can take a little spool away. However, if Buschur ports these turbo housings with his magic, they usually have more power with the same spool. The actual clipping of the exhaust turbine is usually measured in degrees such as 5 degree clip or as large as a 15 degree clip. Naturally the wheel has to be clipped very carefully and tested for balance or the thing could come apart very quickly so don't try this in your garage at home.
Old May 18, 2005 | 10:41 AM
  #409
Fourdoor's Avatar
The original plan was to offer these with the option of the EVO VI TME hot side.... can the titanium exhaust wheel be clipped like the stock wheel? I currently have the TME turbo and want to send it in for the clip of the exhaust wheel and replacement of the turbin wheel... is that still an option? If yes, how much?
Thanks,
Keith
PS: Before anyone complains about people asking price, the situation has changed... clipping was never part of the original set of options.
Old May 18, 2005 | 10:45 AM
  #410
thatsMR2u's Avatar
patiently awaits dyno #s
Old May 18, 2005 | 12:30 PM
  #411
trinydex's Avatar
is anyone else interested in the spool numbers in a regular gear?
Old May 19, 2005 | 10:55 AM
  #412
erioshi's Avatar
Does the current clipped wheel configuration use the 9.8 or 10.5 hotside? If the clipped configuration is based on the 9.8 hotside, will you be offering a 10.5 version (for people running the ti wheel and/or 10.5 housings)?
Old May 19, 2005 | 11:02 AM
  #413
Evo007's Avatar
That was my question because I was going to buy a 10.5 hotside but if it comes with one I don't want to spend the money.
Old May 19, 2005 | 01:10 PM
  #414
trinydex's Avatar
i think you guys are worrying too much. a wheel can be used in either housing just fine... it's not the housing that is changed in size it's the nozzle. plus... this is an exchange based mod. so wahtever you have to core you would get the savings from. best to buy it used or something and core it to save yourself that money instead of buying it new or buying someone else's core from buschur.
it is a legit concern to find out if this wheel is ti/al. but i think it is.
Old May 19, 2005 | 01:54 PM
  #415
Mr. Slappy's Avatar
So did the 20g ever happen? I dont see it for sale on buschurs website.
Old May 19, 2005 | 02:08 PM
  #416
trinydex's Avatar
it's being sold through turbochargers.com at least for now... they may be on buchur's site sooner or later.
Old May 19, 2005 | 04:55 PM
  #417
PVD04's Avatar
Read post #402 on this thread.
-Paul
Old May 23, 2005 | 03:00 AM
  #418
David Buschur's Avatar
Page 27 answers.
Not possible to see a dyno chart as our dyno is sold and gone. Our new MD won't be here for another 5 weeks. The turbo was 2 mph faster in the 1/4 mile than the stock modified turbo that was on my RS, this was also running less boost.
Price, with your core is $850.
I have not tested the turbo at 26 psi yet. I feel it would come close to holding that boost BUT it would take hitting probably 28-30 psi on a spike to get there OR using an external gate.
Turn around time, less than a week.
Clipping is machining the wheel at an angle, this relieves back pressure on the turbine side.
I am guessing at the same boost level about 20 whp gains.
David Buschur
www.buschurracing.com
SBR INC
Jan 6, 2010 10:44 AM
JohnBradley
12
Apr 8, 2008 10:26 PM
badboybr09
Aug 23, 2007 08:04 AM
David Buschur
97
Feb 3, 2006 12:29 PM
