Help with AEM intake
Need help with the AEM short intake. After installing it, i hit fuel cut at 3800 rpm. if i press the gas pedal slow, right after that it goes smoothly to 7000rpm. I have a SAFC which is turned down all the way, the cat delete and the HKS EVC VI set at 1.45. it's not in the bar or psi and i don't have a boost gauge, so i don't know what boost i am running at. But before this i was running fine with a K&N drop in filter at 1.55 with no fuel cut at all.
Are you sure its fuel cut you're getting? Perhaps you have a major leak at the turbo intake? If your MAF reads a certain amount of air and all of a sudden it's not there, that could cause problems that feel like fuel cut...
safc isnt a boost controler i thought its tha a/f controler... avcr is the boost controler
please be more spacific of what you have and i might beable to help.
if its avcr i had the same issues and you have ur boost controler setup wrong and i can post links to how to set it correctly.
i will try to post the pics. i have SAFC and HKS evc4 with the boost gauge in it which reads in mmhg or some thing like that. so there you go. thank you guys for trying to help me.
https://www.evolutionm.net/forums/sh...ad.php?t=98250
probablywont help much
try these two read every thing
https://www.evolutionm.net/forums/sh...ad.php?t=97169
https://www.evolutionm.net/forums/sh...6&postcount=12
sorry fixed third link maby that pic helps
