Help! o2 simulator install.
Old Dec 11, 2004 | 09:40 PM
deekay247's Avatar
Sup guys,
Installed my o2 simulator tonight. I'm afraid I hooked it up wrong. I used the how to for the perrin install and cross referenced with this product I used below.
I used the white wire (o2 simulator signal wire),,,and cut the white wire on the o2 sensor and connected it going back to the harness. I connected the black (o2 sim wire) to a ground,,and the red (o2 sim wire) to the red/yellow striped wire on the o2 sensor. Did i connect it correctly? I saw in another "how to" that the o2 simulator signal wire is supppose to be hooked up the blue wire. Man I'm lost. Help!! Hope you guys understand.
Old Dec 11, 2004 | 09:42 PM
MYEVOVIII's Avatar
Sell it and go buy yourself two 18mm spark anti-foulers and save the $$ and headaches of having to cut wires and have it not work. 14k and not one problem
Old Dec 11, 2004 | 10:01 PM
VTECH8TR's Avatar
Ummm this doesn't work for everyone. I have tried the antifoulers with no luck on 3 evo's including mine. I have the O2 smilator and it works perfect. I just don't know at the momnet how i hooked it up, but i did follow the directions on the website with no problems.
Old Dec 11, 2004 | 10:11 PM
deekay247's Avatar
I have tried the anitfoulers already with no luck. Thanks for the heads up though.
Old Dec 13, 2004 | 11:02 AM
thestaton's Avatar
About to install this myself so Bump
Old Dec 14, 2004 | 11:53 PM
deekay247's Avatar
Freakin checking light came on again after 40 miles. Sold this piece of crap and bought the perrin cel fix. Hopefully the perrin will work.
Old Dec 15, 2004 | 12:01 AM
Silvercar's Avatar
sure you guys doin it right???
Im just wondering how you guys are doing the anti fowler set up?? I ve done it on 6 of are evo s with no cel s and weve put way over 300 miles on em.
tboboy
Aug 7, 2010 03:39 PM
KDamericano
Jun 11, 2006 11:00 AM
Bexa20
Mar 25, 2005 10:55 PM
tweakdsm
Jul 10, 2004 02:46 PM
GTVEVO
May 26, 2004 01:11 PM
