Anybody here spraying nitrous in their EVOs?
Old Dec 14, 2004 | 09:00 PM
  #46
TomeiEvo's Avatar
Hey, Al do you think a shot of 50 hp nos on your evo will make it go deeper into the low 10's?
Old Dec 14, 2004 | 10:19 PM
  #47
gsujeff55's Avatar
Originally Posted by reefro
well good thing he didnt get the co2 like he had planned then
yeah, and prolly runnin lean with no extra fuel for the No2
Old Dec 15, 2004 | 04:50 AM
  #48
evosevengsr's Avatar
Originally Posted by Dr Evo
DSM Motorsport, if I do decide to use it, should I be running the same stock iridium plugs or should I switch to cooler copper plugs?
I use denso 11's
They're cold pulgs but work well for me.
btw which is your evo, dr.evo?
Old Dec 15, 2004 | 06:58 AM
  #49
Dr Evo's Avatar
Originally Posted by evosevengsr
I use denso 11's
2003 Silver Evolution VIII.
Old Dec 15, 2004 | 07:20 AM
  #50
DSMotorsport's Avatar
an additnional 50hp might only be worth 1-2 tenths on a 650+hp car. The faster a car gets the more power it takes to make the same gain in ET and MPH. And on street tires another 50hp and even more torque might not be usable in first gear on the launch.
Old Dec 15, 2004 | 08:11 AM
  #51
ohok..
from where in trini?
well if u need any parts or advice feel free to contact me
Faisal
Old Dec 15, 2004 | 08:33 AM
  #52
Dr Evo's Avatar
ohok..
Faisal
San Fernando, but I live in South Florida.
Old Dec 15, 2004 | 07:00 PM
  #53
TomeiEvo's Avatar
Thanks for the info. Needed that to work out what I had to do on mine. What would good drag slicks like hoosiers do for E.T's?
Old Dec 21, 2004 | 03:19 PM
  #54
blinguskahn's Avatar
Originally Posted by DynoFlash
We tested the netercooler kits a year ago - as Buschur pointed out - they only make power due to the nos - the co2 will take up the o2 and cause the car to choke
I know that you know your stuff al but I totally disagree.
Logic dictates that the nos sprayed isnt even travelling upwards when on a dyno with fans and even more so moving on the street.
How can it get into the intake if the air current is pushing it towards the back of the car? I just don't buy that enough of the nos being sprayed on the intercooler can make 25HP.
As for the afr's changing, we saw this (reefro and I) on a buddies with the sprayer and we had a discussion and concluded that it was probably due to the intake charge being much cooler and therefore contains a higher density of 02. Maybe this is what makes the extra power, but I just can't buy the theory that enough nos is going into the intake to make 25HP.
Old Dec 21, 2004 | 03:30 PM
  #55
matt55's Avatar
Whats the "old rule" for ever 10 degrees you get 1 hp . and you think that the car gained 25 hp from cooler air . WOW
Old Dec 21, 2004 | 04:12 PM
  #56
How cold is NOS dorkwad?
Old Dec 21, 2004 | 04:35 PM
  #57
reefro's Avatar
actually isnt it for every 10 degrees you gain 1% hp?? not just 1 hp...
so in this case to get from 261 to 286 you would need to reduce the temp by about 90F ...
anyone have any idea how cold these n20 sprayers can cool the air going through the intercooler by?? i have no idea
Old Dec 21, 2004 | 04:38 PM
  #58
matt55's Avatar
Ouch
Old Dec 21, 2004 | 05:05 PM
  #59
Arguing over these stupid IC sprayers just baffles me. Who cares what it does on the dyno. Has anyone made any ET/mph gains on the track with one of these?
I firmly belive these IC sprayers are a waste of time and most of the power gain SOME people see is the n2o getting to the air filter and that additional o2% going through the air filter.
Why would you bother to buy and install what is basicly a complete nitrous kit and not spray it into the engine and make the most power you can with the parts you bought.
Spraying the IC seem to me like buying a turbokit, installing it and using the hot air it puts out to heat the windshield. complete waste of your money and parts.
Old Dec 21, 2004 | 05:09 PM
  #60
your spraying nitrousoxide on the intercooler. it goes right through the intercooler, through the radiator and into the engine compartment. Where is the air filter.....right in the engine compartment along side the engine.
the amount of nitrous you need to make 50hp is sprayed through a .018" jet. The jets on an intercooler sprayer are HUGE...they dump the equivelent of a 100+hp shot worth of nitrous in front of the car. how you can think that won't make it through the radiator and into the air filter I can't understand.
