Hallman MBC installed, very happy
Old Dec 30, 2004 | 12:33 AM
plokivos's Avatar
Originally Posted by Zeus
I've got a brand new Hallman... however, mine spikes to 21 and tapers to 19. I was a little disappointed as it was not as "dead on" as I had been lead to believe.
mine doesn't do that. what boost gauge are you doing and where are you tapped in at? turbo or bov?
Old Dec 30, 2004 | 01:54 AM
Zeus's Avatar
I have installed it between the turbo and wastegate (about 18" away). Although this does not seem to be the most popular method, it does seem to be the least likely method to cause "spikes". I have personal experience with another Evo who runs this way just fine.
Don't get me wrong people, I did not post to bash Hallman. My experience lyes almost 100% with EBCs. So, this is more of a probe of those who used the product to see if I truly am "the only one". Suggestions more than welcome. I'm planning on making myself a "pressure cap" in order to rule out any leaks. However, I really don't think I have any.
Old Dec 30, 2004 | 02:02 AM
KILTERMAN's Avatar
How exactly do you set the boost when the MBC is located under the hood ? can you park the car and have some one rev it while you adjust/ watch boost gauge? or do you have to drive it floor it watch boost gauge , get out tamper with it get in drive it floor it watch boost gauge etc.. pretty ignorant question but I honestly dont know
Old Dec 30, 2004 | 04:41 AM
nrcooled's Avatar
^^^Yes, unless you get the incar control then you can adjust from the cockpit. Without the in car controler you will have to do just as you said.
Old Jan 1, 2005 | 09:53 PM
Eon's Avatar
Eon
It only took me a couple of minutes to get the peak right. I did a pull in 1st gear, set it, a pull in 2nd gear set it, a pull in third, set it then I went on the high way, ran threw them to make sure it wouldnt spike higher than I wanted.
Old Jan 1, 2005 | 09:55 PM
Eon's Avatar
Eon
I was just wondering what gauge you are using, I did get a reflash from Al I believe the reflash helps.
Old Jan 1, 2005 | 10:00 PM
Jakeg97's Avatar
exactly, just get the cockpit controller and forget that hassle
Old Jan 1, 2005 | 10:27 PM
Zeus's Avatar
Works P2 Flash, Blitz DTT boost gauge (was dead on compared to the Autometer)... I'll be doing a pressure test Monday to make sure there is no issue with leaks.
Old Jan 2, 2005 | 04:24 PM
kayyoevo8's Avatar
anyone know why my boost goes from a 21psi down to a 15 psi?... and does your boost gauge stay at 18psi vacuum when you start your car?......... anybody know please tell me or pm me... thanks a
lot
Old Jan 2, 2005 | 04:50 PM
caLi4G63's Avatar
I recently installed the Hallman PRO RX on my EVO and right now it goes to 1.5 Bar and tapers back down to 1.35 Bar using the stiffer spring, when I first tried it with the soft spring it would taper to about 1.2 Bar. I've got an even stiffer spring than the stiff one it came with and I'm thinking about trying that out. I got my MBC hooked up from the BOV line.
Old Jan 2, 2005 | 05:26 PM
herbal77's Avatar
Kayyoevo, where is your MBC hooked to, the BOV line or turbo nipplet??
Old Jan 2, 2005 | 05:32 PM
plokivos's Avatar
I would check the upper Intake Line where the BOV connects.
Old Jan 6, 2005 | 12:08 AM
negativeB's Avatar
i use the softest spring and mine doesn't taper more than .5 bar from 1.4
Old Jan 6, 2005 | 07:43 AM
Eon's Avatar
Eon
I am currently going to get the 1GBOV. Everybody says it is way better than the stock. I hope it is.
Old Jan 6, 2005 | 07:58 AM
NOVA EVO's Avatar
I have the Hallman MBC...set it at 20.5 PSI...it's rock solid all the way up...
