Hey people need help
Old Dec 29, 2004 | 08:55 PM
redevo561's Avatar
Talking Hey people need help
Hey whats goin on everyone i have a question every since i i did the s/s clutch my resovoir keep going down could that mean there is a leak or this is normal to keep adding brake fluid ??? my clutch does feel spongy maybe im leakin thru the lines ?? let me kno your thoughts thanks again o yeah i also have a act clutch installed thanks
Old Dec 29, 2004 | 08:58 PM
redevo561's Avatar
ever since*
Old Dec 29, 2004 | 09:22 PM
Jakeg97's Avatar
sounds like you got some air in the line.
when bleeding the clutch line makes sure you fill the reservoir up to the top lip. (way above the fill line like its gonna spill out) i read that trying to bleed the clutch line at the max reservoir level will not work properly
Old Dec 29, 2004 | 09:31 PM
Jakeg97's Avatar
Bleeding the clutch line is not a difficult procedure, however, we even had some issues initially getting the one in the Evo 8 bled properly. Unlike most cars where you can simply begin the bleeding process and just add fluid to the brake fluid reservoir as needed during the process, the Evo 8 brake fluid reservoir must be "over filled" to even get started. Failure to do so can have you pumping nothing but air indefinitely...
http://www.evomoto.com/tech_info.php?tPath=2&tech_id=17
Old Dec 29, 2004 | 09:51 PM
redevo561's Avatar
see i bleed it several times still happends i bleed the clutch by the slave and the reservoir is always filled up but still doesnt feel right and still fluid comes down and need to add some more is there a right way of doing this can it be everytime i let the air out air comes back in ?? thanks let me kno
Old Dec 29, 2004 | 09:53 PM
redevo561's Avatar
is that clear tube running from the slave to a bottle is that needed ??? if so then thats maybe why i have air in there let me kno then i i will try that thanks guys and where can i get that and a speed bleeder i think that can save me sitting there bleeding it forever lol
Old Dec 29, 2004 | 10:27 PM
redevo561's Avatar
Old Dec 29, 2004 | 10:32 PM
Curt@MrLed's Avatar
Former Vendor
push the clutch down once to the floor slowly hold it there and have someone crack the bleeder.forsaying your not leaking fluid, this is the way i did it worked. had to repeat it six times till the air was out
Old Dec 29, 2004 | 11:53 PM
Jakeg97's Avatar
i used a clear tube and didnt have any problems
although if you didnt have a clear tube i would think air could still be in the line. cause how you gonna tell if all the air is out
a speed bleeder would be nice
it took me 3/4 of the damn break fluid bottle to get it bleed right
infam0usndn2nv
Feb 27, 2017 03:39 AM
aznchin07
33
Jan 20, 2012 03:44 PM
pdizzle
Lancer Tranny/Drivetrain Tech
Jul 26, 2010 07:05 PM
MITVRX
Dec 3, 2007 02:41 AM
Go_Lancer_Go
17
Jul 23, 2005 07:09 PM
