Penzoil Synchromesh: Long term review
Old Dec 31, 2004 | 04:46 PM
bolsen's Avatar
Just wanted to give an update. Prior to replacing the fluids, I was getting a pretty bad 3rd gear grind. I replaced the fluid, and that seemed to really help. However, after some mileage, the grind is back. So it's goin in for service.
However, I still like this fluid better, and will stick with it after I get it back.
Anyways, just wanted to give my .02
Happy new year
Old Jan 1, 2005 | 08:52 AM
Zeus's Avatar
It (regardless of which name you buy it under) seems to be the best shifting fluid out there for the Evo tranny right now (at least for those who have TRIED the different fluids). However, it needs to be changed more often as its non-synthetic formula seems to break down quicker. Since you can pick it up for $5 a liter under the Pennzoil banner at your local Auto Zone, I change it about every other oil change. Hell, I'm under the car anyway.
BTW, I have over 30,000 miles on this fluid to date...
Old Jan 1, 2005 | 10:20 AM
Thoe99's Avatar
I was gonna write a longterm review also. I had a 2nd gear grind when shifting at high rpms, so I also put in Pennzoil Syncromesh. It also helped temporarily, but now the grinding's back. Is this something they cover under warranty?
Old Jan 1, 2005 | 12:34 PM
Zeus's Avatar
Don't let the fluid "mask" a real issue if you have one. Get it checked out.
Old Jan 1, 2005 | 06:46 PM
evo81's Avatar
i've been using BG,and it's been good.i'm gonna check out the Pennzoil Syncromesh soon
Old Jan 2, 2005 | 12:16 AM
Thoe99's Avatar
Did you have a gear grinding issue on stock fluids? What about after you switched to BG for a while? That's what Pennzoil did. It worked perfectly at the beginning, but now it's like it wore out too soon or something.
Old Jan 2, 2005 | 12:49 AM
evo81's Avatar
no grinding on stock fluid.also no grinding on BG.i guess i know how to shift.so your saying not to get the Pennzoil?zeus seems to be happy with it.i better just stick with whats safe.BG
Old Jan 2, 2005 | 02:02 AM
Thoe99's Avatar
If you read the responses and see the statistics/polls on this forum about grinding gears, you'll probably figure out that it's not a driver's issue. One of the polls reports 70% owners having a gear grinding issue. Do you really believe 70% of owners don't know how to properly shift? (yes I am aware that the poll doesn't really represent all owners) However, there was a sample of about 350 owners that responded, so it "could" be a rough gauge.
https://www.evolutionm.net/forums/sh...ad.php?t=99121
Old Jan 2, 2005 | 03:09 AM
EVO8LTW's Avatar
My guess on the frequency of gear grinding problems is that most people are shifting too fast for the stock restrictor and clutch line. To shift this car as fast as a Honda without changing these parts or putting in a more stiffly sprung clutch (which will lessen the "delay" of those parts) seems to wear out the syncros quickly.
Old Jan 2, 2005 | 05:20 AM
Zeus's Avatar
I had the occasional 1-2 grind... I removed the restrictor and this went away for the most part... along with any "burning of the clutch". The action was still "notchy" though. After moving to the Syncromesh/shift (same stuff made by Pennzoil) that went away to. If I let the tranny fluid go more than about two oil changes, it will get a little notchy again, and I will occasionally have a grind. I attribute the returning grind to the fact that the Pennzoil allows me to be pretty lazy with the shifts. When it "wears down", it is less forgiving of a lazy leg.
Old Jan 2, 2005 | 06:56 AM
Hammerr's Avatar
Please excuse my ignorance and help me out here. What restrictor and how do I remove to try it out? Can I put it back if I want?
Old Jan 2, 2005 | 07:21 AM
Az3ar's Avatar
That fluid saved my life. I have 3K miles on it and no grind.... very smooth and I love it. I will change it every 6K
Old Jan 2, 2005 | 03:06 PM
bo0oost's Avatar
BG is the best I have ever used. Only drawback is it's notchy when cold, but when it's warmed up, never a problem. Shifts smooth as silk.
Old Jan 2, 2005 | 03:25 PM
slushfund's Avatar
The how to on the restrictor is at http://www.evomoto.com/tech_info.php...=3_4&tech_id=4. Its titled Braided Clutch Line / Restrictor Removal.
Old Jan 2, 2005 | 03:42 PM
Hammerr's Avatar
thanks a bunch for the restrictor link
