installing cam gears will make the belt slip?
Old Jan 21, 2005 | 05:29 AM
Derek888's Avatar
has anyone experience this before?
Old Jan 21, 2005 | 06:01 AM
VTECH8TR's Avatar
sure if you do a half *** job, but if you use wire ties and take your time you should be allright.
Old Jan 21, 2005 | 06:11 AM
Derek888's Avatar
Originally Posted by Whoosh
Your injector duty cycle is much better off when you err on the conservative side. Cam gears, while allowing you to smooth out a rough idle, are not absolutely necessary (David Buschur actually advised me to not get because of slipping). .
Old Jan 21, 2005 | 07:22 AM
superz's Avatar
Leave the stock ones in there and get a good tune, this will get you a very good idle. You can slip on new cam gears without causing any problems with the belt, however don't attempt this job if you feel even a bit unsure of what you're doing.
Old Jan 21, 2005 | 07:24 AM
jrhecker's Avatar
i have also heard that cam gears are unnecessary unless you are doing a turbo upgrade as well.
what engine management are you using?
Old Jan 21, 2005 | 07:49 AM
Derek888's Avatar
Are you refering to me? If so then ill be going with the HKS F con V pro.
Old Jan 21, 2005 | 09:02 AM
jrhecker's Avatar
in that case you are probably ok to go without the cam gears, i have heard that the emanage and the v pro are sufficient for cleening up the idle without gears.
i am using the emanage, and a friend of mine has 272's with an emanage, the idle is really rough at a stop, but fine once your moving even a little bit, oddly enough the idle becomes near perfect when you turn on the AC at a stop
Old Jan 21, 2005 | 10:15 AM
cruizinmax's Avatar
Actually he is talking about the cam gear adjustment slipping, not the belt slipping on the gear.
