ARC Intake
Old Jan 22, 2005 | 10:10 PM
Jakeg97's Avatar
Originally Posted by EidolaDream
Dont take this wrong, Im not makeing a statement, but a question. What makes theres better than stocker. From what Other tuner companys both in the states and out of the states say the stocker is pretty much the s h @#$
anything stock is "s h @#$"
dont get me wrong , the stock intake box is good , but give the engine an aftermarket intake and you can feel the difference
Old Jan 22, 2005 | 10:15 PM
Jakeg97's Avatar
Originally Posted by dilat3d
Is the ARC Induction box worth the money? Is it a good intake in general? I haven't seen many people with one, is there better out there?
depends if you want a woosh sound when you let off the throttle while on boost or not
Old Jan 23, 2005 | 12:14 AM
Derek888's Avatar
I took off the stock airbox with my K&N drop in filter and you could hear the stock bov pretty loud.
Old Jan 23, 2005 | 12:23 AM
Ztypestock8's Avatar
^ Yeah thats true, I tried it at the 1/4 track and I ran slower times when I took the stock top off.
Old Jan 23, 2005 | 12:34 AM
plokivos's Avatar
if you want to get more out of your aftermarket short ram, you need to take the under tray out.
stockers are restrictive because of the filter element. that's all. the box itself is designed well, but what ARC is doing is making the airbox bigger so it could hold more air inside the box. Also, it uses less restrictive filter elements.
thus, creating better intake induction with lesser restriction, and this makes car go faster, throughout the powerband, unlike the short ram design, which is good for high end hp.
Old Jan 23, 2005 | 12:41 AM
Curt@MrLed's Avatar
Former Vendor
just in air filter yeah, you throw an itake tube on there youll lose power, unless you have some kind of engine mang.
Old Jan 23, 2005 | 02:06 AM
hkfeet's Avatar
I love this intake but once I get my xede, and my wideband and egt probes installed I dont think I can handle tweeking it with the intake from what the other tuners experienced. Ill just stick to the stocker with drop-in unless there is something designed just like it without any maf issues.
Old Jan 23, 2005 | 05:40 PM
Jakeg97's Avatar
Old Feb 14, 2006 | 10:39 PM
Middle Man's Avatar
Sorry to bump up and old thread (i did a search)......but does anyone know if the ARC airbox fits with an OPTIMA D34 battery?
Im thinking of getting both for my IX.
Cheers,
T
Old Feb 15, 2006 | 05:43 AM
trinydex's Avatar
the stocker is a good unit...
i wish i could put mine back on... but i broke my tabs and i'm also considering going to a blow through maf setup with ecu+ :\.
Old Feb 17, 2006 | 09:30 AM
Jakeg97's Avatar
Cheers,
T
if the optima can fit with the stock airbox, then yes it will
Old Feb 17, 2006 | 01:14 PM
andross85's Avatar
Does it affect performance when it get hot?
somebody told me its get hot when you stop with engine on
mohed.amb
Dec 21, 2015 09:58 PM
Evasive EVO
36
Nov 17, 2008 02:22 PM
jaytengan
23
Nov 29, 2006 02:50 PM
Mach 8
Oct 24, 2004 10:36 AM
emr-power.com
May 28, 2004 03:26 PM
