Nearly hit the windscreen at 130mph
Originally Posted by Fourdoor
And if the car is running lean, that means the ECU is seeing less air flow than the motor is actually getting.... putting you farther away from fuel cut.
Keith
Keith
Originally Posted by NOVA EVO
Incorrect...the high-flow filter allows MORE AIR into the intake tract than the ECU is expecting at a given RPM...to protect from a potentially damaging overboost condition, the ECU will cut fuel to save the engine. The solution is to get a tune like a DynoFlash to remap the ECU and take out the fuel cut.
This is why I hate EvoM.... all the missinformation. Preach on master and god of all things automotive.... we will shut up and listen to your wisdom now.
Rob_GPT
15
Nov 8, 2016 02:52 AM
