Pulling Timing Error
Old Feb 4, 2005 | 11:37 PM
inphluence's Avatar
Hey guys, I was told i had a Pulling Timing problem with my evo, in third gear, shortly after my turbo spools and i hit around 4000 rpm, it seems like the turbo bogs for like a sec, then it picks up again. and then at 4th gear it does the same thing around 3500 rpm. How or what do i do to solve a pulling timing problem? Thanks in advanced guys.
Old Feb 5, 2005 | 01:02 AM
LateSleeper's Avatar
Could it be the colder temps and crappy winter gas?
Old Feb 5, 2005 | 07:15 AM
Deepseadiver's Avatar
Would a boost leak do the same thing?
Old Feb 6, 2005 | 12:46 AM
inphluence's Avatar
at first i thought it couldnt of had to do witht he cold temps, but todays it was rather warm out, and it's still doing that. I don't know whats up =\
Old Feb 6, 2005 | 12:49 AM
UT_Evo's Avatar
Did you recently install a TBE w/ no MBC? Mine likes to jump around the boost levels a bit just because the ECU is confused with the extra flow...so it sorta does the same thing, but it's a bit more random than your's sounds, just an idea
Old Feb 6, 2005 | 12:57 AM
nebolic's Avatar
you need to list your mods first before we can help decided what is wrong with the car. Post all mods.
Nebo
Old Feb 6, 2005 | 01:39 AM
inphluence's Avatar
sorry, I only have a Turbo XS RFL BOV, I don't think it is that because i've had it on for monthsbefore this started to happen. Everything else on the evo is currently stock.
Old Feb 6, 2005 | 02:30 AM
bluevo's Avatar
You maybe having some leak: upper ic connections, your aftermarket bov, or check your vacuum hoses.
Old Feb 6, 2005 | 07:02 AM
EVOTEXAS's Avatar
It's your TurboXS. Every single one of those I have seen can't hold steady boost. Get a Hallman MBC. Rock solid.
Old Feb 6, 2005 | 07:10 AM
gadsmevo's Avatar
Re-Read that evotexas. He has a TurboXS BOV not a boost controller.
If you are stoclk I would dump the BOV for a stock or a MR one.
Old Feb 6, 2005 | 07:12 AM
EVOTEXAS's Avatar
Good call.
Old Feb 6, 2005 | 08:13 AM
DynoFlash's Avatar
Sounds like the ecu is hearing some knock and pulling back timing
A SURE FIRE WAY to test this theory
Let the tank go almost empty and pour in a couple of gallons of 100 octane of better race fuel - reset the ecu by disconnecting the battery for a coupe of minutes and then see if the problem goes away
If its a knocking issue - I can fix it with a reflash of your stock ecu - you can try a mail in flash for $199 or come down to Pruven for a fully custom tuned flash with 2 hours of dyno time for $299 on sale right now
Thanks
treager
Aug 27, 2014 11:28 PM
NUR
Jan 12, 2014 07:25 AM
unihappytime
Nov 26, 2013 10:27 PM
rolly1818
Jan 21, 2010 08:34 AM
David Buschur
909
Jun 22, 2008 06:20 AM
