Evo8 Throttle problem
Old Jan 9, 2014 | 08:33 AM
NUR's Avatar
NUR
Hello people, i am facing a problem with my evo8 and would like to know what you guys think of it, My TPS sensor was not working a month back, and i had to replace it with a new one, now the car runs and idles fine but sometime when i drive and press really light on the throttle say accelerating at 1500-2000 Rpm the car jerks very hard but it does not happen everytime, only when i am very soft on the throttle (Thats how i used to drive before the TPS issue happened, never stalled or had this prob), Another symptom i noticed that is say i am driving at 3rd gear and see a stoplight, putting the gear back to neutral causes the ROM to drop below 1000RPM, but this does not happen all the time. No issues when i am pulling the car hard, these happen when i am normally driving the car around. Please help Thanks
Old Jan 9, 2014 | 11:31 AM
jrainwater's Avatar
When you replaced the tps did you have it calibrated again since it was new?
Old Jan 9, 2014 | 11:46 PM
Biggiesacks's Avatar
Is your check engine light on? Is the car modded?
Old Jan 10, 2014 | 06:46 AM
NUR's Avatar
NUR
Yeah the issue happened on my way back after i got fp green installed and tuned, engine check was on later the old tps was showing 0% throttle opening at idle, which means its not working , the new tps was calibrated in a rush maybe thats the issue i guess.
Old Jan 10, 2014 | 09:03 AM
There really isnt much in the way of calibration for the tps. It has a little bit of room for adjustment, but i just dont see this being your main problem. If it where me, i would start with a boost leak test and work my way from there.
Old Jan 12, 2014 | 07:25 AM
NUR's Avatar
NUR
Thanks for your opinion, will take the car this week for a checkup, but if there was a boost leak i would have RPM drop at a certain gear without putting it back to neutral right? like say i pulled at 3rd till 6k rpm and rather than putting it back to neutral and braking i let go of the throttle to cross a vehcle or something and then accelerate again? theres no problem in the situation mentioned above so i suspect its the tps, lets hope nothing serious.
razorlab
Sep 14, 2019 11:08 AM
blknblubkrdude
17
Apr 15, 2018 01:22 PM
mister1161
Mar 29, 2016 06:54 PM
Prolifik
Aug 27, 2013 03:18 AM
BlackDismay
Dec 12, 2011 06:05 PM
