turning off engine with downpipe
Old Feb 9, 2005 | 10:00 AM
LEVIII's Avatar
Originally Posted by IOevo
im pretty sure i know what it is.
your new "invidia" DP, does it have a flex joint? if not, then whats happening( PROBABLY) is that all the stress from the motors major moving parts (crank shaft, connecting rods) are slowing down considerably fast, and causing the motor to shake. ever played with a gyroscope? when the inner wheel is spinning fast, the gyroscope has little vibrations and moves smoothly. when it slows down the balance gets all off kilter and the g-scope falls over. So, when engines are turned off, the motors momentum causes it to shake, because of the rapis reduction of movement. with the stock DP there is a flex joint in it, that lets the vibrations from the motor kind of "absorb" into the flex joint and your car doesnt shake.
having a flex joint in any DP i believe is mandatory because without it, you will be putting high ammounts of stress on the connecting points where the turbo connects to the exhaust manifold, the engine head, and anywhere else that connects to the motor. ever seen an exhaust muffler shake when someone revs the motor? do you want that shake to travel all the way up to the exhaust manifold and head connection, possibly putting high stress on those bolts? not me...
But the stock DP has no flex section.
Old Feb 9, 2005 | 10:04 AM
Curt@MrLed's Avatar
Former Vendor
true^^^^ but where the dp. connects to the o2 its a swivel joint. if the dp is installed correctly. there should be more than enough flex there to not have a prob.. i dont.. or it could be he is paroniod like most of use were when we started modding
Old Feb 9, 2005 | 11:13 AM
dipdm's Avatar
Sorry late post someone already addressed the flex piece on the DP.
Last edited by dipdm; Feb 9, 2005 at 11:17 AM. Reason: cached web page and didn't see that it was already posted
Old Feb 9, 2005 | 11:49 AM
Derek888's Avatar
I just want to make sure this is normal but I do think it does have to do with the dp not flexing as much as the stock one. But I remember the mechanic tightening the dp it made a creaky noise like it was bolted onto a spring thingy. I thought that piece would help absorb any vibration.
ryan0414
14
May 10, 2008 02:54 PM
EvolNinja
Apr 8, 2008 12:38 PM
liquidh
Jul 19, 2007 03:33 AM
jeffbum
May 27, 2007 10:56 PM
99AllTurbo
Feb 18, 2004 05:21 AM
