bad turbo problems?????????
The shaft play won't do a thing, after my engine blew, the turbo's shaft play was crazy, and they all said it'd be fine, it'd just make the turbo's life shorter...but this was Mitsu techs
shaft play is funny, many people thing it is fine, but if you can move the shaft arround a whole lot then you have issues not if it just wiggles a lil bit it is fine, and how did you gernade you engine?
a few question for you..
-if you are bone stock then why were you changing the intercooler? was there problems with your old one (you should still be under warranty) or was that the first mod you were doing to the car????!!!
-Do you have a boost gauge?? If not get one.. Get a really cheap crappy one even.. just get something so you can tell how many #'s the car is running and you will know if your turbo is wasted
-and a LITTLE oil is fine.. nothing to worry about..
-Lastly.. Does the car FEEL slower or different then it once did???
ok the reason im puting the intercooler on is because i got an upgraded 1. i got about 8 grand in parts and more on the way i was just waiting to put them on. when i desided to put the car togeather the 1st thing i took off was the fmic. then the issue came along and i have a boost gadge just not in so u think puting that in will narrow down my problem a bit?
Originally Posted by EvoJeff
Well if you drive as bad as you type then I'd say your car is in big trouble. Take the time to write a coherent post and I'll take the time to write an informative response.
I think that when you hook up the gauges though everything should read fine... I bet a lot of it is mental....
Because I find it disrespectful to write like that. His post should be clear and concise where people are trying to solve the problem, not decypher what he wrote. If he won't respect this board and the members by writing somewhat correctly then I won't give him my respect.
Now maybe if the guy spit in your face, I could see a problem, maybe you should learn some respect and not waste everyone time posting about what seems to be a personal probem...
If you need attention, please consult a psychologist.
