Fp zero
Old Feb 6, 2017 | 09:05 AM
djelliott978's Avatar
Fp zero
Been thinking of going to a FP Zero, from a FP Black bb, any1 rinning this turbo, is there more to this turbo ? Thank's for all the Help,
Looking to make 650+ E85
Old Dec 22, 2019 | 04:26 PM
hokiruu's Avatar
I don't have any personal experience with them but If I were going that route I would seriously consider EFR8474 based on their specs "on paper" and design.
Old Dec 22, 2019 | 06:08 PM
ctfpevoVIII's Avatar
you can easily make 650 with a zero on e85.
Old Dec 23, 2019 | 11:11 AM
2Lejit's Avatar
I feel like you will be able to do that with the FP black you have. I don't remember who it was but just the other day someone did 670ish whp out of an FP Red. Maybe someone from the English Racing camp?
Old Dec 26, 2019 | 10:19 AM
Abacus's Avatar
The fp black mhi should make 700whp + all in on a dynojet with good tuning,fuel and setup. A bit more on the SS housing and it will have less back pressure out the top.
I recently made 675 on an SS Red but that was max effort . I would consider the SS red as more of a 630whp/8000 rpm turbo. At least on a 2.2 with a full exhaust.
Old Dec 30, 2019 | 12:24 PM
2Lejit's Avatar
That impressive! I've got a ported MHI housing on my Xona FP Black and I'm curious as to where its going to run out of steam at. I was a little concerned about spool but being a 2.3, it is just slightly lazier than the old FP Green that I took off of it.
Old Dec 30, 2019 | 12:32 PM
2Lejit's Avatar
I contemplated hard on the SS housing..
Old Jan 28, 2020 | 12:06 AM
nd_danial's Avatar
Hi, i made 745whp on the fp zero. ran out of injectors. 1650cc FIC high Z.
Old Feb 1, 2020 | 05:12 AM
justboosted02's Avatar
Originally Posted by nd_danial
https://www.youtube.com/watch?v=Cix6rnb1GFk
what fuel are you running?
Old Feb 1, 2020 | 07:33 AM
2006EvoIXer's Avatar
injectors are stated at the end: FIC1650.
Old Feb 1, 2020 | 07:53 AM
ForceFed4g63's Avatar
I'm sure he means what kind of fuel. I'm assuming E85 if he's maxing out 1650's.
Old Feb 3, 2020 | 12:23 PM
yep, I thought E85 but was curious.....
I'm looking at going into these power numbers for my current build and I'm not sure what size injectors to get yet.
i don't have e85 available, probably will just be using 100 oct pump
Old Feb 3, 2020 | 04:31 PM
nd_danial's Avatar
Yes that was on e85.
On Ron100 pump gas + methanol injection, I got 645whp but stopped the tune due to the head lifting. I believe there there is still abit more. Maybe 670, 680whp perhaps..
Old Feb 5, 2020 | 06:15 AM
wizzo 8's Avatar
I'm currently switching over to an Fp Zero from an mhi BB Black. I made 622whp on Boostin performance mustang dyno. Hoping to crack that 700whp mark with the Zero. I should be getting tuned sometime in April or May.
Old Feb 5, 2020 | 04:26 PM
nd_danial's Avatar
That will be easily possible with adequate fuel supply and e85.
Good luck!
pls1968
Jul 13, 2020 01:16 PM
djelliott978
Feb 10, 2017 02:28 PM
italia_evo9
34
Oct 3, 2016 10:15 PM
Nadaevo
Mar 17, 2016 03:00 PM
agiaquinto
Apr 14, 2011 05:43 PM
