Slow Spooling
Old Feb 11, 2005 | 09:47 PM
RalliArtEvoVIII's Avatar
Slow Spooling
What could possibly make a basically stock evo with BPU's (bov, intake,exh, boost gauge) spool slower than it should? I been runnin my evo at WOT to test it and it feels like the turbo kicks in a little slower than it should and i dont feel that strong pull as much but i feel it. I remember when i first drove it BEFORE the mods and it feels like it kicked a lot harder (i now have a ACT clutch too) esp when i downshift.
Old Feb 11, 2005 | 09:52 PM
note: the MBC isnt installed yet, im sure that will help once i get it in a few days, but im trying to fix this issue now, thanks
Old Feb 11, 2005 | 09:53 PM
EVOKing8's Avatar
a leak check the lines
Old Feb 11, 2005 | 10:04 PM
is there an easy way to check for this? like a specific way to check? Where do u suggest checking, i doubt its my IC pipes cuz i even took my bumper off and i tightened the SH*T out of those clamps, so i think it might be the vac lines like the turbo/wastegate to stock BC, etc...what other lines would it be? thanks, also when i took it to WOT (my boost gauge reads BARS) and it went to about 1.4, maybe 1.5 bar and as soon as it hits 1.4, the needle starts shaking and it tapers to about 1.2/1.3BAR and the needle shakes the whole time. I dont think its normal cuz before 1.0bar, the needle jsut rises but doesnt start shaking, once it gets near full boost, it starts shaking, could it be a sign of a leak?
Old Feb 11, 2005 | 10:10 PM
hyun's Avatar
boost leaking from the bov?
Old Feb 11, 2005 | 10:23 PM
hanahawaiian's Avatar
im sorry BPU what mean.. im heard word before but im forget... I heard BPU supra and Evo BPU? BPU like Boost? something?
Old Feb 11, 2005 | 10:34 PM
Doc's Avatar
Doc
I think its a leak
Old Feb 11, 2005 | 10:39 PM
What.. I just want know what is BPU that all.. plus im Deaf and I dont heard it.. I just SAW word is BPU
Old Feb 11, 2005 | 10:51 PM
Doc's Avatar
Doc
Sorry man ,I was just being immature,I apologize....
I think BPU means , B-asic P-ower U-pgrades but im not sure.....
Old Feb 11, 2005 | 10:53 PM
It okay.. Thanks..
Old Feb 12, 2005 | 06:55 AM
Fourdoor's Avatar
It is also possible that you have just gotten used to how fast the car is. Or, if you put on an intake without fuel tuning to compensate for running too lean you may have actually lost power.
BPU = Basic Performance Upgrade
Keith
Old Feb 12, 2005 | 07:15 AM
EVO8LTW's Avatar
I get the shaky boost gauge needle and unstable boost if I set the gain too high on my electronic boost controller. I think it's the BOV. If it doesn't hold shut and opens a little, it seems like it tends to stay a little open. If boost doesn't hit too hard, then the needle is rock solid and it holds the pressure. Sounds like you might have both a BOV and a boost leak. You can make a pressure tester with under $10 in pvc parts if you have a air compressor. Do a search here.
Old Feb 12, 2005 | 12:47 PM
hmm i might try that, but today i noticed my lower IC piping leading to the turbo was kind of loose, dont know if that caused it so i took it for a run at WOT to about 5-6k rpm each gear and still the same, when the boost kicks in, i dont feel that strong pull im supposed to feel and another issue i've had for a bit is when i shift gears, no matter how fast i shift, the car bogs noticably, not hard, but it bogs enough and sometimes when i do 2-3shift it kicks hard and u could notice my ACT clutch grabbing hard. Question is: whats causing my car to bog inbetween shifts? is it cuz i need to bleed the clutch?
Old Feb 12, 2005 | 01:18 PM
GIsnickers's Avatar
If it is a leaky BOV, how do you know though?
Old Feb 12, 2005 | 01:26 PM
also is it normal that theres a bit of oil on the inside of my intake pipe near the turbo connection side of it. it wasnt much but it was fresh.
