! Stock Boost Questions !
Old Feb 15, 2005 | 10:05 AM
Timujin's Avatar
22PSI max and tapering off to 19PSI when going through gears 1st - 4th round town. 5th gear at speed and floored (65+mph) 22PSI no taper up to one something MPH. DEFI mechanical boost gauge tapped into vac line from manifold to fuel pressure regulator.
Old Feb 15, 2005 | 10:09 AM
GIsnickers's Avatar
Should I put stock airbox back in until I can get a DynoFlash ?
Old Feb 15, 2005 | 10:10 AM
Timujin's Avatar
Put stock box on period.
Old Feb 15, 2005 | 10:30 AM
EVOTEXAS's Avatar
Intakes make great power. They drive fine too when you have a tune. I recommend TurboTrix very highly for expertise AND customer service.
Old Feb 15, 2005 | 10:33 AM
GIsnickers's Avatar
Ok I will put the stock box back on, thanks everyone. Maybe someone should sticky this kind of information.. Would be helpful to new owners. I hate being a newbie
Old Feb 15, 2005 | 04:24 PM
oguratevo's Avatar
My MR about 20psi at approx 3400~3500rpm and tapers down at 5,500~6,500 rpms.
Old Feb 15, 2005 | 04:26 PM
GIsnickers's Avatar
Put the stock back on, it feels much more punchier than the AEM intake...
Kind of concerned with the fact that my Guage still only goes to 10 or 12psi though...
What exactly could be going on here? I'm totally lost.
Old Feb 15, 2005 | 04:31 PM
Evo-VIII's Avatar
did you tighten the lower ic pipe clamps?
Old Feb 15, 2005 | 04:34 PM
GIsnickers's Avatar
The ones on the driver side look fine. Not sure on the Passenger side.. Would'nt I have to take the Front bumper off to get to it anyways?
Old Feb 15, 2005 | 05:32 PM
Aby@MIL.SPEC's Avatar
Originally Posted by GIsnickers
mine rarely is hitting 19 and dropping to 10 or 12..
Interesting.
Take your car to the dealer & have them check out the stock boost solenoid. Mine failed @ ~3500 miles.
I experienced similar low boost levels. Maybe the diaphram is torn in your w/g throttle actuator?
Old Feb 15, 2005 | 06:26 PM
GIsnickers's Avatar
Think I solved my problem, just spoke with a guy here "Laakness" .
He had a similair problem to mine.... he had the same guage as me....
Mine hovers @ 10 VAC when the car is off, and goes to 20 VAC when the car is on... I thought it was odd that it wasn't at 0 when the car is off but whatever.
I have a faulty guage.
Old Feb 15, 2005 | 06:52 PM
Timujin's Avatar
Try getting the gauge that tops out at 30PSI. Oh yeah, my gauge goes directly to zero when the car is off.
Old Feb 15, 2005 | 06:55 PM
GIsnickers's Avatar
Mine currently goes up to 30, that was just a sample picture. Same company though... Thanks to everyone who helped me though, I was able to nail all possible issues thanks to you guys.
Old Feb 15, 2005 | 06:58 PM
Curt@MrLed's Avatar
Former Vendor
mine was the same stock..
Originally Posted by EVOTEXAS
It will vary depending on weather, gear, RPM you punch it at, etc. The ECU is programmed stock to hit 19 and taper to about 16 by redline. However, the turbo, the boost solenoid and the engine are all mechanical pieces and will vary their behavior.
Old Feb 15, 2005 | 07:00 PM
Curt@MrLed's Avatar
Former Vendor
yes, i had lost about 30 horsepower when i orig. put an intake on it..
aka.ralliart15
34
Mar 15, 2011 10:53 AM
mattz09
Apr 11, 2010 08:55 AM
David Buschur
69
Jun 30, 2007 09:47 AM
EvilDylan
88
Apr 22, 2005 02:55 PM
03LaNcErES
May 22, 2004 10:40 PM
