Removal of Restrictor Pill..4th grinds??
Old Feb 15, 2005 | 11:49 PM
BluEvo3037's Avatar
I read somewhere about 4th gear problems when the restrictor pill is removed....Having just heard this...what can i do to fix this??
-John
Old Feb 15, 2005 | 11:57 PM
Curt@MrLed's Avatar
Former Vendor
you should leave the rest. in.. change your trans fluid to bg fluid.. if it still grinds you need a clutch or your synchros are bad
Old Feb 16, 2005 | 11:30 AM
EVOla_VIRUS's Avatar
Seems like it might be aggrivating a problem that is allready there.....beware of the 03 Evo as they have dr jekel and mr hyde transmission lol
Old Feb 16, 2005 | 07:53 PM
ACTman's Avatar
-John
Gear grind has no relation to the restrictor.
Old Feb 16, 2005 | 08:02 PM
EVOTEXAS's Avatar
Old Mar 6, 2005 | 01:43 PM
BluEvo3037's Avatar
That may be true...but on another thread i read someone doign the same thing and having problems with there gears aswell.....I can't seem to find the thread right now tho
-John
Old Mar 6, 2005 | 03:30 PM
EVOTEXAS's Avatar
-John
correlation is not causation
Old Mar 6, 2005 | 03:48 PM
WildRice's Avatar
The clutch slips more with the restrictor in place as lockup is delayed. This slipage might allow the trans shafts to better match rotations. Whatever the reason, there is no fix other than replacing your syncros if they are a problem. Some people like to treat the symptom or improve performance by using other than the factory trans oil. There are some excellent threads on this subject.
badwheel
Jul 3, 2017 10:52 AM
Chewie4299
Apr 6, 2006 07:44 AM
superman105
18
Aug 24, 2005 03:58 PM
exhaust_note
Aug 11, 2005 09:44 PM
cml899
Apr 29, 2005 06:33 AM
