Engine No start after flash...
Old Feb 17, 2005 | 08:22 PM
  #31
ExViTermini's Avatar
Originally Posted by TurbotrixRacing
If you flash a computer with an 04' in an 03' box ..it wont start then stop with it dumping fuel. Its not a bad flash, as i've used it many times before. The person that had the flash also did his cams, which on the phone discovered that his cam angle sensor was backwards .. so i dont think anyone should point blame until we figure out what went wrong. I can tell you one thing, he has an 03' flash which i've used prob 150 times, and had reflashed it again when we thought something might of happend with it. ... Same result. I told him to take it to the dealer then see if the car starts with their flash,, but i guess he's using al, which wont help his problem..
Mark
Turbotrix
I'm still just waiting to see if he can fix the problem. Time will tell.
Old Feb 17, 2005 | 08:25 PM
  #32
lil'evil_evo's Avatar
edit: nevermind
Old Feb 17, 2005 | 08:29 PM
  #33
double post
Old Feb 18, 2005 | 10:36 AM
  #34
TrinaBabe's Avatar
Well now it sounds more like he jacked up the cam install Maybe he put the intake cam where the exhaust cam should be Im interested in finding out what has happened.
Old Feb 18, 2005 | 11:13 AM
  #35
damnit you got me..I just switched the cams on accident and instead of bolting the cam sensor in there I just glued it to the cam
Old Feb 19, 2005 | 12:23 PM
  #36
DynoFlash's Avatar
No I don't think he messed up his cam install - because he just called me and his car is running like a swiss watch now with just the revised flash. I was 100% confident that I could resolve his problems with the revised reflash code.
Old Feb 19, 2005 | 03:51 PM
  #37
I got the ECU back today, the car runs great and has a very smooth power band all the way to redline. NO codes whatsoever except for the secondary o2 sensor due to the testpipe, but I have the fix for that Thanx again AL for the flash, its working beautifully
Old Feb 19, 2005 | 09:35 PM
  #38
DynoFlash's Avatar
Glad to hear it ran and gad you are enjoying it
Old Feb 20, 2005 | 07:13 PM
  #39
DynoFlash's Avatar
BTW - you forgot to tell me how your buddies can ran with his flash
Old Feb 20, 2005 | 08:55 PM
  #40
He is really happy with it and it pulls a lot smoother than turbotrix did. We got the white one goin again tonite, finally put the clutch in, it is doing very well too. Thanx
Old Feb 21, 2005 | 07:35 AM
  #41
DynoFlash's Avatar
Cool brother - I am glad you both are sorted out now - enjoy
okevolutionVIII
68
Jun 20, 2012 05:55 PM
ambystom01
Lancer Troubleshooting
100
Nov 1, 2005 07:38 PM
Stumpy221
Lancer Engine Tech
14
Feb 8, 2005 09:00 PM
