Help Needed car wont turn over.
Old Feb 6, 2005 | 10:26 AM
Stumpy221's Avatar
Ok heres the story, yesterday morning i went to start my car it wouldn't turn over. But then i tried it again and it was fine. Then i parked it in a parking lot to do some errands. to make a long story short i come back and the car will not turn over. it will crank, and the ignitiion will start up, but it will not turn over.
Mods= Intake, headers, exhaust, bored TB, Battery relocation and RRM PB.
I had some tools in my car so i decided that maybe my grounding point in my car loosened. i checked it and it was fine. Then i figured i would reset the ecu so i disconnected the battery for 15 min and again tried to start, still nothing. Then i figured maybe it was gas (even though i had at least half a tank) so i picked up a gallon of gas Still nothing. Then i disconnected the pb, still nothing. Checked my spark plugs and they were good.
My question, does anyone know what could be wrong?
Which wire on the harness is for the fuel?
Could my ecu have fried?
Could my PB Fried?
Keep in Mind i have had these mods for over a year and absolutely no problems.
Someone help.
Old Feb 6, 2005 | 10:31 AM
Iamkar33m's Avatar
Battery might be the culprit... maybe not enough charge to fully turn over the motor.
Old Feb 6, 2005 | 10:33 AM
josh930's Avatar
2nd that or the alternator
Old Feb 6, 2005 | 10:36 AM
Stumpy221's Avatar
I tried to jump the battery as well, and still nothing
Old Feb 6, 2005 | 10:38 AM
josh930's Avatar
How many miles on your car? Could be the starter oralternator. What sound does it make when you try to start it?
Old Feb 6, 2005 | 10:44 AM
Stumpy221's Avatar
only like 27,000
it sounds like the ignition is firing, but no end result.
Old Feb 6, 2005 | 10:52 AM
josh930's Avatar
If the ignition is firing the only problem could be fuel. Injectors could be clogged with particles of dirt. Try runing a fuel system cleaner through it if you can get it to start. 27,000 is very low to have problems like that.
Old Feb 6, 2005 | 10:55 AM
WADADLIG_OZ's Avatar
Stick or matic?
If it's a stick try to push start it?
WADAD
Old Feb 6, 2005 | 10:58 AM
Stumpy221's Avatar
auto
Old Feb 6, 2005 | 02:33 PM
diamondstar03's Avatar
how did you check the plugs? when you removed them was there a gas smell in the cylinder? if not it would probably be the fuel pump. with that many miles it should not be bad but stranger things have happened.
Old Feb 7, 2005 | 12:57 AM
rhyzin's Avatar
check your crank sensor. there's a wire harness by the passenger side engine mount.
there's a skinny black ground wire on the driver side of the engine next to the cam sensor. i think that's the ground for your coil packs. make sure that and cam sensor is okay. check your pb connections too. if your rpm wire got cut, your engine might not start from that either.
check fuses and then get your codes checked. even tho a cel might not be on, you might have a pending code that could help.
Old Feb 8, 2005 | 04:15 PM
Stumpy221's Avatar
ok im pretty sure its the fuel pump, or relay. Because when i checked my spark plugs they were dry, and only had a hint of fuel smell to them. granted the car has sat outside for a while, but when you turn the ignition, shouldn't there be at least some fuel going into the engine.
Anyone know where the fuel pump and relay are located???
Old Feb 8, 2005 | 04:21 PM
Z_Lancer_Man's Avatar
Its your piggyback. I had a piggyback in the summer, and my car wouldn't start. It would sound like it wanted to, but just wouldnt turn over, like it needed more gaas, but wasn't getting it. I called RRM and they put the latest fuel maps on the PB and sent it back and I tried it again and it still wouldn't start. Sometimes I could get it to finally turn over and then it would be fine, but then I would turn the car off for a while and it wouldn't turn over again. I ended up just selling the PB to someone else on here and the pb worked good for him for a while then he started getting the same problems. I would contact RRM and talk to Rob and see if they've figured out what the problem is.
Old Feb 8, 2005 | 04:50 PM
Stumpy221's Avatar
even if it ran perfectly fine for a year?
and even when i take it off the car still doesn't start
Old Feb 8, 2005 | 09:00 PM
Hmm, I guess if you take out the piggyback and then reset your ECU (15 minutes unhooked battery), and it still doesn't turn over, than it very well may be a fuel pump problem. You could see if the stealership would look at it under warranty - maybe you can hide all yoru mods
Anubis7
Mar 30, 2017 09:00 PM
blackmambe_evo7
Sep 13, 2016 06:54 AM
briantorres1991
Jul 10, 2016 09:40 AM
SkippygoluckyIV
Nov 15, 2015 12:59 PM
SkippygoluckyIV
Nov 13, 2015 03:31 PM
