How dangerous is this?
Old Feb 19, 2005 | 12:34 AM
4TUN8's Avatar
Typhoon intake
TurboXs turbo back
MBC
running this on the stock ECU.
I tried some searches.....hopefully I don't get slapped with the "search!!" comments.
Old Feb 19, 2005 | 12:44 AM
ez76's Avatar
the typhoon intake is bad news, the other stuff is reasonable
why is it bad news? for that i think you'll need to search. suffice to say it is not doing you any favors, especially without tuning
Old Feb 19, 2005 | 12:46 AM
4TUN8's Avatar
I plan on getting the car tuned, just not right away. I'm pretty sure that I'll be all right to run the car this way, I'm just being extra careful I guess.
Old Feb 19, 2005 | 12:48 AM
RaceBiscuit's Avatar
"dangerous???" I wouldn't call it dangerous, per say. But like ex76 said, you'll need to tune for your mods (especially the intake). Get it done right (TUNING) and you'll get nothing but satisfaction from your mods.
Old Feb 19, 2005 | 12:49 AM
feriosi'evotwin's Avatar
ive heard the typhoon makes ur cel light up something about to much airflow do some research on it
Old Feb 19, 2005 | 12:50 AM
plokivos's Avatar
it's not dangerous. All intakes will give you some lean spots and extremely rich spots. That's why you need to tune it. I would wait until you get tuned to put the intake on. Meanwhile, the stock intake could do the job just fine with those mods.
Old Feb 19, 2005 | 12:54 AM
ez76's Avatar
It's not just the intake per se.
The K&N typhoon in particular is notorious on our cars:
https://www.evolutionm.net/forums/sh...t=typhoon+lean
https://www.evolutionm.net/forums/sh...ad.php?t=78543
There now you don't need to search as much :-)
Old Feb 19, 2005 | 12:55 AM
plokivos's Avatar
looks like the pipe design.
Old Feb 19, 2005 | 01:36 AM
4TUN8's Avatar
lean is bad.....I made my order with NOPI on thursday night, I wonder if it's too late to cancel my order....
Old Feb 19, 2005 | 01:41 AM
ProStreetOnline's Avatar
We do not recommend using the Typhoon intake on EVOs. Stick with the Injen Intake, or HKS RS. And you can always use the tried and true K&N drop in filter.
Good luck
Old Feb 19, 2005 | 02:45 AM
4TUN8's Avatar
Thanks for the help =x
I knew I should have done more research.
Old Feb 20, 2005 | 06:47 PM
sonics36's Avatar
the k and n is fine you would get a little more power out of the other but you have to get flashed you will proably lose power with that intake.but it will be safe
Old Feb 20, 2005 | 07:51 PM
03venom's Avatar
as stated above, pass on the intake. Everyting else will be just fine... you'll run pig rich on the stock tune, but you will not hurt anything.
Old Feb 20, 2005 | 10:27 PM
BuLocal's Avatar
How high are you turning up the boost??
Old Feb 20, 2005 | 10:52 PM
j8's Avatar
j8
I had a K&N in my car for exactly one hour and then removed it and sent it back. Over 4000 RPM fuel cut would come on. I even talked to K&N and they told me to turn my MAS upside down. I don't like to play games with the car. If it does not work correctly I send it back. You do need to tune the car for the intake, but I would not recommend this intake. Go with the drop in K&N or HKS. Just my two cents.
leecavturbo
Site Feedback / Suggestions
83
May 6, 2009 07:46 AM
spt
EvoM Announcements
10
Sep 28, 2007 10:51 AM
deanjones
Jan 31, 2007 09:25 AM
Static
Apr 20, 2004 10:34 PM
