I think we all should get an Oil catch can.
Originally Posted by djtmotorsports
The oil is from the breather hose. It happens on all turbo cars.
This is pretty common. In some extreme cases, we've seen the oil build up so bad that it starts backing up into the MAS and causes some erratic readings. A quick clean-up gets everything back in check.
Originally Posted by ex-honda
After looking again at the picture. On the first picture, there is oil in the front where it connects to the air box and the breather hose is down more. So if it is from the breather hose, why do I have oil before the breather hole and near the air box? If it is all from the breather hose, shouldn't all the oil be down more and none near the air box coupling?
So does the catch tank rectify this problem? I have been noticing some oil on the floor, but it is alot lighter in color than engine oil. And my intake is just like yours.
Hi,
If your K&N we're really overoiled, it might drip down there. However, what you see is probably from the breather hose. The K&N oil starts out tinted red, so I don't think it would even look like the pics?
I have two DIY catch cans, one on the ventilation side and one on the breather side. The ventilation side catches a LOT more oil than the breather side.
My stock MAF pipe was also coated in oil when I installed my samco hoses. This is why I decided to install the catch cans, and from other posts and now personal experience, I'm glad I did the ventilation side as well.
Take care,
FB
Take care,
FB
If you do get a catch can, be sure it has a substrate inside of it to take the oil particles out of the blowby gas before it recirculates. I had a Greddy can (round one) and I came to find out that it was just an empty can. Needless to say it didn't catch much.
Dave
jbigelow
14
Nov 5, 2005 06:42 PM
Widebody Lancer
70
Mar 15, 2005 10:08 PM
Spec C
11
Nov 19, 2004 03:03 PM
