Buschur Stg4 + Methanol (dynosheets)
Mods: Buschur Stage 4, TME 6.5, Aem Ems, Methanol injection.
Was very impressed with the power that was made on the methanol. Even more so that the pumpgas methanol combo made more power than the just race gas. Shows how well the Buschur products and the power they can make. The methanol injection was run with 100% methonal, no 50/50 mix. Boost would spike 28psi then fall to around 20-21psi by redline.
Run# 16 is Pumpgas only
Runs #35,36,37 are with pump gas and methanol.
It was set to come on at 4psi and ramp up as the boost comes in harder. I am sure the customer will chime tomorrow when he gets home as he has a long drive to Florida.
Originally Posted by 03BREvo8
how often would you say you have to refill the meth...
Originally Posted by Mercenary3
Dave B. said soemthing on the order of every 2 gas fill ups. Depends a lot on driving.
Any idea on what the power difference would be with a stock '05 turbo instead of the TME turbo?
mAN. i was gonna go up with him.. i will probably be up there with my car for a tune in a month or two.
you were highly recommended by luis.. and after seeing his dyno. it confirmed my thoughts.
Methanol injection
When I had my race car we tried running gas vs. methanol and found the car had more Tq and much better off the corner power with methanol.
Bad points: Made engine run too cold at times and hard to warm-up. And you need to flow a river of it to make a motor run on straight Methanol like we did.
Oh, and did I menshion it's corrosive...
MachC5
MachC5
