Defi BF EGT Temps
Old Mar 13, 2005 | 11:12 AM
LateSleeper's Avatar
Defi BF EGT Temps
What are you guys getting for EGT temps on your Defi BF gauge? My sensor is mounted where cyclinders 1 and 2 merge.
This is what I get:
Idle: 450 Celcius
Cruise/Freeway: 600-700 Celcius
WOT: 850 Celcius
I noticed that the car runs really lean when cruising or idling. My AEM Wideband shows 14-15 to 1 air/fuel at idle and cruising.
Old Mar 13, 2005 | 11:14 AM
GTKage's Avatar
temp looks ok, but a/f seems kinda off forsome reason, i doubt our car run that lean while cruising. btw what are your mods?
Old Mar 13, 2005 | 11:26 AM
I should be more specific about the wideband reading. I won't have any logs until my Xede is upgraded. Mods are Xede and Turboback exhaust w/ high flow cat.
Idle: 14.5 to 15
Cruising (maintaining speed, light throttle touch): 13-14
WOT: 11.0 to 11.6
Old Mar 13, 2005 | 01:27 PM
koolade9's Avatar
all the above is normal. for egt's at WOT, keep it < 900 C and you won't be torching the motor, 850s are good.
air fuels are good as well.
Old Mar 13, 2005 | 01:31 PM
JTB's Avatar
JTB
I see 850 to 900c on a prolonged 4th gear pull on my Defi BF -- mounted 1" off the head in Cyl 2.
You are right where you are supposed to be.
Old Mar 13, 2005 | 03:27 PM
Jorge T's Avatar
AFR on closed loop cruise is 14.5~15. Open loop (WOT) is a different story.
Old Mar 13, 2005 | 04:32 PM
evo81's Avatar
agree.your good.same here also
Old Mar 13, 2005 | 06:43 PM
Thanks for the input guys.
deza3000
Oct 4, 2015 11:09 PM
crcain
46
Mar 8, 2010 07:35 PM
lightspeed1
17
May 2, 2009 12:25 AM
RavSpec
Evo 'For Sale' Exterior Styling
189
Jul 7, 2008 03:05 PM
