HELP...Diagnose my problem please!!
Old Mar 24, 2005 | 10:25 AM
Evofurry's Avatar
Exclamation HELP...Diagnose my problem please!!
I was at the track fri night...got one run in and ran a 12.1@117 at 2.8psi on c-16 fuel.....my run last year with same modds was 12.0@122.4 ...before i went to the track on pump gas and 23psi my car was pulling hard and running very strong, it seemed when i turned the boost way up for the track with the race fuel is sounded like air was passing by and not going into the engine, almost like mayeb something was loose..Today i was driving and actually chirped the tires from 1st to 2nd running low boost like 21psi. Also, when im running the lower boost im not getting that "air" sound. I wish i could explain the sound better. It kinda shutters and sputters a tiny bit, mayeb a foul plug???? i have no clue. Point being, my car seems faster with low boost and pump rather then high boost and race fuel. I beat a viper from 45mph-140mph last Sat on 21-22psi. Im gonna try doing new plugs today and see how it feels, ill take some pics of the plugs and let some of the profesionals see what they think. Thanks guys!!
Old Mar 24, 2005 | 11:00 AM
EvoG8r's Avatar
What kind of set up do you have? Are you running stock piping?
Old Mar 24, 2005 | 11:07 AM
Evofurry's Avatar
no i have the Buschur 580 turbo kit, and just about every bolt on from buschur along with 272's, and head studds..255 fuel pump and 870cc inj. It was dynoflashed last year too the old turbo the Buschur 500 and has yet to be tunned to this tubo..
Old Mar 24, 2005 | 11:15 AM
Evofurry's Avatar
wheres the help!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 24, 2005 | 11:19 AM
redevo561's Avatar
Maybe you need to tune it for the 580 turbo kit maybe thats why it feels slower when your boosting higher rather than when boosting at low psi it feels strong there will be diffrent a/f rations with a bigger turbo first thing is get it tuned for the 580 turbo kit then pin point problems
Old Mar 24, 2005 | 11:22 AM
clappton's Avatar
You probably overcame your blow-off valve when you turned the boost up, forcing your turbo to work harder to supply the requested 28 psi, and heating the **** out of the air. The hot air means less timing and less power overall.
Old Mar 24, 2005 | 11:23 AM
redevo561's Avatar
^^ thats true more boost doesnt always meen more horsepower
Old Mar 24, 2005 | 11:35 AM
umiami80's Avatar
If you are tuned for a smaller turbo, chances are you need more fuel and proper tuning. Also yes you maxxed out your BOV, get a race one to run 28PSI, maybe look into HKS units.
Old Mar 24, 2005 | 06:29 PM
Evofurry's Avatar
thanks guys, wich other BOV can bolt onto the Buschur intercooler pipeing, anyone now??
Old Mar 24, 2005 | 06:32 PM
MuslimEvoFreak's Avatar
Your best choice would be an HKS or a Greddy BOV
Old Mar 24, 2005 | 06:47 PM
4TUN8's Avatar
I bet that noise was compressor surge....
Old Mar 24, 2005 | 08:10 PM
timzcat's Avatar
Talk to Buschur about the BOV. I am pretty sure he has something that will hold the boost.
If you are running the 1G and it is not crushed then I would say at 28 it can't hold anymore.
Old Mar 25, 2005 | 03:00 PM
umiami80's Avatar
Gert the HKS, it is a PULL Type Vs. a Push type. So no mattter HOW much boost you rrun the BOV will hold and then open against the preassue when you realease it.
Also your car is probably knocking or running to lean.
Old Mar 26, 2005 | 02:34 AM
trinydex's Avatar
get your 1g crushed it doesn't come crushed from buschur... after that should hole 35 psi all day.
