View Poll Results: JDM MR diverter valve, love it or left it ?
Great valve, no problems.
87.94%
Problems, didnt like it
12.06%
Voters: 141. You may not vote on this poll
JDM Mr diverter valve
Old Mar 29, 2005 | 03:57 PM
  #31
marksae's Avatar
If you tighten the clamps too much, they'll bend and break. I usually tighten them til they're snug, then give it another 1/2-3/4 turn.
Old Mar 29, 2005 | 10:16 PM
  #32
silverEVO8's Avatar
I'm sorry, but I don't understand how the BOV can cause or cure boost spikes..... Doesn't the BOV only work when you let up on the pedal so the compressed air in the intake has someplace to go when the throttle plate is closed? I guess a defective or ill chosen BOV could leak and maybe cause some loss of pressure, but I really don't see how it could have too much effect on anything. After all, isn't the stock BOV designed specifically for the EVO? Would it not be designed for the blowers we have?
Old Mar 29, 2005 | 11:59 PM
  #33
Wicked's Avatar
The difference would almost be non existant. But what I assume the change in spike is that you will have less of a spike in boost with a leaky DV as opposed to one that doesn't leak. I also have the MR DV and have had no problems with it, it flutters a little bit under low boost, but no big deal.
Old Mar 30, 2005 | 01:13 AM
  #34
marksae's Avatar
There's a difference between how a valve was designed to work and how close a valve is BUILT to those design specs. One of the biggest performance limiting factors of the factory DV is the plastic material. This limits material strength and surface smoothness needed for a good seal. Any type of boost leak would be less than ideal. I believe Silver Surfer did a leak test on the factory DV and found it to leak before 19 psi. And when you have a leak, your turbo will have to spin faster to achieve the same amount of boost. This robs hp.
Old Mar 30, 2005 | 06:56 AM
  #35
bigjhoney's Avatar
WOuldnt a leaky dv cause a high spike than one that is not leaking because the turbo has to work harder to achieve same boost?
Old Mar 30, 2005 | 08:38 AM
  #36
marksae's Avatar
If the air from your turbo is leaking out the DV, it will not reach the manifold and cause a spike in boost. Just think of a leak like having a hole in your IC piping.
Old Mar 30, 2005 | 08:40 AM
  #37
k270kmh's Avatar
My MR valve is PERFECT!!!
Old Mar 30, 2005 | 09:20 AM
  #38
silverEVO8's Avatar
I don't know about that..... Ever have a leak in your IC or IC pipes?, the car will run like crap if it runs at all. Unless the DV is leaking from the pressure side to the athmosphere, I cant see how that would be like a leaking IC pipe......
Old Mar 30, 2005 | 09:44 AM
  #39
marksae's Avatar
Okay, bad example. A leaky BOV will only leak at or near full boost.
Old Apr 6, 2005 | 11:00 PM
  #40
UT_Evo's Avatar
The two aftermarket valves that work best that I've seen here, are the 1g crushed, and the JDM MR DV, I; however, sadly still have the stocker pos, me have no money. But I would definitly go for the MR one
Old Apr 7, 2005 | 04:51 AM
  #41
matt55's Avatar
Just got my MR bov runs/works great , pressure tested the system and the MR bov held 26psi !! The stocker was leaking by 13psi !! This is The only bov that should be on are cars .
Old Apr 7, 2005 | 06:51 AM
  #42
silverEVO8's Avatar
OK, I'm quoting myself because I've installed the JDM MR BOV in my car and answered my own questions...... I never had any boost spikes before and I was not aware of any problems with my stock BOV. I got the new aluminum BOV because I thought it looked cool and was a "real" MR valve......
Well, to my great and pleasant surprise, the new DV seems to improve performance and driveability a good bit Now, the driveability part might be a placebo effect, but the new DV definitely holds boost better and perhaps because of that, it makes the car run stronger. For me it was a definite improvement plus it looks pretty cool
Old Apr 7, 2005 | 08:25 AM
  #43
evo8chris's Avatar
I have the JDM MR valve. I noticed better boost response with it. It does make my car stall if I do a quick clutch in during low speed driving. You just need to adjust your driving habit to adapt to it. No biggie.
werd
Old Apr 7, 2005 | 03:55 PM
  #44
Derek Baker's Avatar
Jdm Bov
Does anyone here know where I can get a JDM BOV at a reasonable Price?
Well at least from a vender that has one in stock at a good price.
Thanks
Derek
Old Apr 9, 2005 | 02:16 AM
  #45
evo8chris's Avatar
www.gruppe-s.com
ask for cal.... he'll take care of ya. tell him chris with the black evo in san jose sent ya =)
