Boost cut w/ no CEL?
Old Mar 29, 2005 | 09:18 PM
DC2Dorifto's Avatar
I believe I was hitting boost cut tonight, every time I got to 5-6k rpm in 3rd the car would just jolt and not go anymore. I turned the boost down to 18 (from 20.5) and the problem went away. But it never threw a code. Should I reset the ECU anyways and leave the boost lower until it warms back up outside?
Thanks.
Old Mar 29, 2005 | 09:23 PM
chinto's Avatar
ya that could be it or it could be just a bad tank of gas.. how cold is cold down in FL??
Old Mar 29, 2005 | 09:24 PM
DC2Dorifto's Avatar
It's like 50-55 degrees outside right now, I tuned the MBC in ~80 degree heat. I did try a different gas station this time... I could just keep it down and switch brands next tank. Why wouldn't the CEL come on though?
Old Mar 29, 2005 | 09:26 PM
chinto's Avatar
that little temp change shouldnt do it. up here in nj i hit boost cut when it gets 20 deg and colder running about 21 psi on 93 oct.
just cuz you hit boost cut once or twice doesnt mean the cel would be thrown. just run thru the tank of gas and try it again if it keeps goin then ask again or shoot me a pm maby you have a hole or a vacume leak some where
did this just start happening after installing a boost guage just reading what u have installed.. wich line did you tap possably if you taped the FPR line instead of the line to the inside of it possably with the colder weather ur actually running higher boost then you think
Old Mar 29, 2005 | 09:41 PM
bigjhoney's Avatar
Ive hit boost cut about 10 times, and I only had a light about 3 out of those 10 times. If it didnt throw a code I wouldnt worry about it aslong as you turned the boost down.
Old Mar 30, 2005 | 03:14 AM
DC2Dorifto's Avatar
I tapped the line that comes off the intake manifold, the same spot that the factory boost gauge does. I stlil don't have a flash/tune yet, I really have to get that done soon I think now.
I had it tuned in this temperature before and it was fine, then I gave it another turn when it got hot and never thought to change it back.
peisden
Apr 12, 2015 03:29 AM
eddy5201314
Aug 12, 2013 07:59 PM
erik.bouse
12
Dec 12, 2010 02:39 AM
fbikawi
May 19, 2007 05:30 AM
MattevoVIII
25
Feb 18, 2007 05:25 PM
