How much power can stock clutch handle?
Old Mar 30, 2005 | 06:45 PM
BigAeVo's Avatar
Basically what the title says, at the moment i have Greddy Ti catback, Helix DP and High flow cat, Hallman boost controller set at 20, Dyno flash through the mail, 255 lph fuel pump. I want to add 264in/272ex cams and a bigger intercooler. Will my stock clutch be able to handle this much increase in power? any information would be helpful Thanks.
Old Mar 30, 2005 | 11:14 PM
GREDDY's Avatar
350-360AWHP easy. Also depends on the way you drive too. If you have a heavy foot then obviousely your clutch will go out faster.
Old Mar 31, 2005 | 11:45 AM
ProStreetOnline's Avatar
It should handle it... just don't launch
When you need an upgrade, some see us.
Old Mar 31, 2005 | 01:00 PM
evo81's Avatar
i've see a evo here(joevo8) run at the track with 370 whp on stock clutch,and went home without any problems
Old Mar 31, 2005 | 01:04 PM
SterlingEvo's Avatar
Agreed, and prostreet makes a great flywheel
Old Mar 31, 2005 | 01:06 PM
redevo561's Avatar
Its all about how you drive to be honest with you if you can drive and not slip it to much you should have no problems
Old Mar 31, 2005 | 01:22 PM
blackevoVII's Avatar
If you do not launch the car you will have no problems for a long time. I had 314 to the wheels on the stocker for 21k. My clutch was only glazed when it was replaced. Still had a decent amount of friction material left too.
Evojj25
Jun 14, 2014 08:08 PM
jag0
25
Aug 9, 2010 07:36 PM
EvolNinja
Mar 27, 2008 11:20 PM
TurboIX
Oct 11, 2006 07:59 PM
IamsoEvo
Oct 4, 2004 03:48 PM
