My Turbo Kit Experience....
Old May 2, 2005 | 07:10 PM
  #91
Evol_VIII's Avatar
Whats up with the A/f's being rich as hell?
Old May 2, 2005 | 08:06 PM
  #92
jj_008's Avatar
Its 10.5:1. I think stock is below 10:1. Rich = safe. I like rich .
I am getting 28-30mpg on the freeway. Even my in town mileage has gone up to 21mpg.
Old May 3, 2005 | 05:36 PM
  #93
Evol_VIII's Avatar
Yeah, rich usually is safe but that is a little over the top. It is ok for your street tune but the race tune needs to get leaned out.
Old May 3, 2005 | 08:43 PM
  #94
umiami80's Avatar
Hell 11.0-1 is fine.
Old May 3, 2005 | 08:49 PM
  #95
jj_008's Avatar
The race tune was meant for 28 psi. I could only reach 25-26 psi. Shiv left it rich so I could easily turn up the boost and be ok.
Old May 3, 2005 | 08:55 PM
  #96
jj_008's Avatar
It would be fine, but what happens if you get a tank of bad gas or other possible bad situations that may appear?
How much Hp am I losing by running 10.5:1 instead of 11:1? 10hp? 20hp?. Is the 20hp worth it to me? No.
Like I wrote earlier, Shiv made 25hp more on pump gas, but backed it back down for safety.
Old May 3, 2005 | 09:48 PM
  #97
umiami80's Avatar
Your fear is really unfounded, I mean 11.0-1 is really REALLY safe. Running as rich as you do your gona foul your plugs after a while. What if you get bad gas? What if you get into an accident? what if you slip and fall and crack you rhead open? What if you wake up one day and are missing your *****?
Seriously running 11.5 or less is more then fine, some people run 12.0 and that is fine, I keep it at 11.5 for my preference, anything under 11 is just WAY rich, you are missing out on a lot of power, smoother powerband, spoolup, and throttle response Fuel tuning is MASSIVE on a turbo car 11.0 is just as safe, seriously try it Your modding your car right? If you were REALLY scared, then you wouldn't mod it, right?
Old May 3, 2005 | 10:02 PM
  #98
shiv@vishnu's Avatar
You guys do realize that jj 008 and the rest of the northwest don't get 93oct, right?
Shiv
Old May 4, 2005 | 03:54 PM
  #99
Evol_VIII's Avatar
Shiv
That makes no sense at all. So what if he only gets 91oct. The car still doesn't need to be in the mid 10's in the A/F's. He will either have to run a little less boost or less timing. It's not like fatining up the A/F will make the power that 93oct does so what's the point.
Old May 4, 2005 | 07:44 PM
  #100
jj_008's Avatar
I am going to let Shiv answer the tuning related questions. All I care about is that my car is a lot faster then it was before and I can beat it up all day long (at drag strip or road course) w/ no ill effects. If Shiv feels like 10.5:1 is what is need for our crappy gas to do it, then so be it.
Old May 4, 2005 | 07:56 PM
  #101
umiami80's Avatar
10.5-1 is overly rich, you don't have to be an expert tuner to know that atleast an 11.0-1 should be used even on 91, and again just use timing advance and retard.
Old May 4, 2005 | 07:57 PM
  #102
Thanks for the tuning lesson. I'll keep that in mind the next time I tune a car.
Shiv
Old May 4, 2005 | 09:37 PM
  #103
Karash's Avatar
Originally Posted by jj_008
And thanks for the compliment. The dyno wasn't real ego friendly, but i gained around 70whp over cars w/ cams on pump gas and thats what really matters.
Don't worry about the hearbreaker dyno...take it to the track and see how it does. I think I tuned in at 266 on a MD after my cams and tune, but I can promise you its a ton faster than a previous pull on another dyno at 251
Old May 4, 2005 | 09:41 PM
  #104
Karash's Avatar
Oh, and the comments about 11.5 on bad gas are great! Made my day...thanks!
LOL
Old May 4, 2005 | 09:48 PM
  #105
jj_008's Avatar
I really don't care about the dyno numbers, its the difference that counts. The car has excellent power on pump. It was a night and day difference coming from the stock turbo.
As for taking it to the track, well I am about the worst driver on the net. My best 92 octane run was a 13.1@111mph w/ a 2 sec 60'. I couldn't put a Buschur stage 4 into the 13's.
