My Turbo Kit Experience....
Originally Posted by shiv@vishnu
Thanks for the tuning lesson. I'll keep that in mind the next time I tune a car.
Shiv
Shiv
Originally Posted by EVO-6.5 (KSA)
Ttt
I re-dyno'd on a dynojet and through down 372hp/330tq on 92 oct.
https://www.evolutionm.net/forums/sh...d.php?t=160649
I fixed my wastegate issue and can now boost 30+psi. I did a compression test and it read 160 across. So far so good.
I have the new SMART setup for my XEDE, but I still haven't installed it.
thanks for all the info
the 3076 is good but i would like to see some one go over 450AWHP with thim .
but it seems that if i go with the GT35 i could get my target of
500 WHP.
thanks once more
500 WHP.
thanks once more
I gained 40whp at 26 psi on race when I first got dyno'd so if I add that number to my dynojet numbers I would have 412 whp. With 28psi, on 100 oct, I could get around 440whp.
With a 60 trim compressor on a GT3076 you should be able to hit 500whp at 30psi. The spool up would probably be only 300RPM better then a GT35R though. IMHO, I would go with a GT35R if you want 500whp.
Is your 3076r have a .63A/R or .82A/R or something else?Im thinking of getting buschurs 3076r turbo kit.But want a streetable turbo kit.How does the 3076r feel after it was tuned?
THANKS
THANKS
THANKS
THANKS
+1.........I am debating between the 3071 and 3076 on pump and alky. what i am looking for is how much more power will the 3076 make over the 3071 on pump and alky? also, is the spool up difference worth it to get the the extra power of the 3076 over the 3071?
THANKS
THANKS
the 3076 on 110 will make something in the vacinity of 500-550hp... no more...
the 3071 on the same will make 400-450hp maybe 470, some have done it. but that's really it i thinks... you'll be hard pressed to break a usable 500 hp on the 3071. can't tell you about 3071 spool tho...
THANKS
THANKS
Mine
Originally Posted by trinydex
i sat in a 3076 equipted car... you feel nothing until 3800 rpms... THEN, it's take off.
