My 10.5 Hotside Install & How-To
Old May 11, 2005 | 06:49 AM
  #61
Dyno4mance's Avatar
Sorry to be negative....great write up by the way
Old May 11, 2005 | 07:01 AM
  #62
SuperHatch's Avatar
No it's ok, I take bad news fairly well. It's not like I did a writeup of my clutch install and you're telling me I have to drop my tranny again. I can pull the O2 housing in a hour or so, won't be the end of my world if I have to change that gasket.
Thanks for the compliments btw.
Old May 11, 2005 | 09:57 AM
  #63
91z28-350's Avatar
I'm assuming you're referring to the gasket between the O2 housing and the hotside? What gasket do you recommend there?
Old May 11, 2005 | 10:28 AM
  #64
SuperHatch's Avatar
He recommends the stock gasket... it's a multi-layer stainless sheet design, as opposed to a compressed steel composite which came with my O2 housing.
- Steve
Old May 11, 2005 | 10:30 AM
  #65
EvolManiac's Avatar
did you notice a difference between 1k to 4k rpm range? Was it a faster spool up?
  #66
Dyno4mance's Avatar
Really has to be the Mitsubishi one...
Superhatch, you're right, not a big deal...It is possible to remove the 02 housing with everything else in situ if you have the right tools....
Old May 11, 2005 | 10:35 AM
  #67
EvolManiac's Avatar
same question up two posts up
Old May 11, 2005 | 10:44 AM
  #68
SuperHatch's Avatar
The 10.5 hotside on a stock turbo should result in a slower spoolup than stock, due to the stock 03 turbo having a higher mass rotating assembly than the Evo 6.5 TME Ti Turbo. However, I noticed no increase in spoolup compared to stock, just a reduction in tip-in throttle response. The O2 housing may be the reason that I havn't lost spoolup. I would like to think that with the Ti internals my tip in response would have been the same as stock too.
- Steve
Old May 11, 2005 | 10:49 AM
  #69
SuperHatch's Avatar
To expand on that for people who do not know what I mean by tip in response versus spoolup...
If I floor it at 2k RPMs, I notice no difference when the turbo hits full boost as to before the 10.5 hotside was installed.
If I am holding partial throttle around a turn at high RPMs (4k +) and am giving the go pedal slight nudges, the response of the turbo is worse than it was with the stock hotside and O2 housing. Not tremendous but noticeable.
- Steve
Old May 11, 2005 | 10:54 AM
  #70
sr20det91's Avatar
Thanks for the how-too.
I did notice you were using a torque wrench, could you add the specs. to you're write up. Also I would like to add for those who are worried about working that close to the radiator and any resulting damage may want to take a peice of flat cardboard and tape it against the back side of the radiator to prevent any bent fins or sliced knuckles. Thanks again for the excellent write-up.
Old May 11, 2005 | 11:06 AM
  #71
SuperHatch's Avatar
I'll get torque specs if I get the chance. And I used cardboard about half the time... should have used it the whole time, but sometimes I'm lazy
Old May 11, 2005 | 11:38 AM
  #72
evo81's Avatar
- Steve
why didn't you just use the stock o2 housing then?also,why didn't you port&polished everything while you did this? i would think the stock o2 housing(port/polish) would be better than an aftermarket one.that should of gave you more whp,and a better i feel i believe.good write up.if you want it to be a sticky,find the mods in the how to section,and pm them up saying take a look at this thread.that's how i got my how to made into a sticky.
Old May 11, 2005 | 11:50 AM
  #73
SuperHatch's Avatar
I don't think you understand what I said. The O2 housing helped offset the lag induced by the 10.5 hotside, the lag would have been WORSE if I had kept the stock O2.
And I did portmatch every component. I simply didn't put that in this writeup since it has no bearing on how to install the parts.
- Steve
Old May 11, 2005 | 12:31 PM
  #74
EvolManiac's Avatar
did you have to replace the turbo seal and clips?
Old May 11, 2005 | 12:42 PM
  #75
SuperHatch's Avatar
Since I have no idea what you're talking about, no
