Help on Spark Plug and Compression number ...
Old Apr 12, 2005 | 05:11 PM
timzcat's Avatar
colors are slightly off in the manual but see 17-8 for diagram.
Old Apr 12, 2005 | 07:03 PM
GOKOU's Avatar
Timzcat,
Thanks a lot. I went outside and took a look and you were right. The one next to the yellow stripe is blue and does go to the EGR valve. There are two vaccuum lines that go to the EGR. The yellow goes straight to the EGR where as the blue goes to the EGR via the EGR solenoid. Don't know how it came loose like that. Not sure if this was my issue or if this will effect performance but it's plugged in now. I'm guessing there could be something else but need to wait till tomorrow. I also reseted the ECU.
Thanks for the help.
Old Apr 12, 2005 | 07:17 PM
timzcat's Avatar
Vacuum leak will cause all sorts of problems. Unmetered air entering intake. MAP sees more load then exits because vacuum is low. etc etc.
It should be it.
Emperor 4g63
16
Jun 8, 2017 12:50 PM
Jared Murphy
11
May 15, 2017 08:45 PM
icmanevo
Oct 3, 2012 02:36 AM
pinoy6969
Pacific Northwest
Jul 27, 2012 12:53 PM
mugen777
13
Dec 8, 2008 03:43 PM
